Hydroboost Conversion, how to with pics
Old Jul 11, 2009 | 10:21 PM
  #21
Atomic's Avatar
I have a gauge for that
Thanks man
I think this and the 14b write up add up to about 4,000 words.
Old Jul 11, 2009 | 10:26 PM
  #22
ChevyTruck's Avatar
something else
Yea the 14 bolt is where I need to be first. I would like to do a hydroboost later this summer maybe in the fall time, need something better to stop the 35's she is getting worse every week.
Old Jul 16, 2009 | 12:26 AM
  #23
black06's Avatar
has anyone had a successful swap with the rack setups?
Old Jul 16, 2009 | 07:08 PM
  #24
truckmann's Avatar
So as far as the hoses go the two pressure hoses are the ones that can easily be found at any parts store and the low pressure hose is the dealer only one? If that is the case is there anything really special about that hose other than the bend in the top? Because it sure doesn't look like it's worth what the dealer wants for it to me.
Old Jul 16, 2009 | 07:23 PM
  #25
Atomic's Avatar
Nope, nothing special as far as I can tell. Felt just like a coolant hose. I dont know the heat/oil rating of heater hose, but that may work. Size is 3/8" I think.
Old Jul 16, 2009 | 07:36 PM
  #26
truckmann's Avatar
Good to know. I'm sure there is a rubber hose made rated to handle the heat and oil. Shouldn't be any different than the rubber hose that comes with transmission coolers. One would just have to be careful to install it in a way that it won't get kinked.
Guess I'll be buying myself a hydroboost system as soon as I get some other things paid for!
Thanks for the write up and nice pictures!
For anyone looking for hoses the numbers to search for from the parts store are:
80338 and 92092
Old Jul 25, 2009 | 09:29 PM
  #27
jamespeek's Avatar
what about OBS guys? I have a 1991 gmc sierra, and want to do this. do the NBS, 99+ trucks use DOT3 on the gear box and p/s pump? can i use my p/s gear box and p/s pump? thanks!
Old Jul 25, 2009 | 09:35 PM
  #28
ssavalanche's Avatar
There were OBS trucks with hydroboost too. Just usually diesels from what I have seen. You still can use your steering box and pump. These Hydroboosts have been around for a long time even before your body style. I have seen them on late 70's early 80's trucks Diesels dont have vaccuum to run a regular booster so thats what they had.
Old Jul 25, 2009 | 09:54 PM
  #29
616 of 933's Avatar
do you stop better?
Old Jul 25, 2009 | 09:55 PM
  #30
Atomic's Avatar
the booster is just a pump that pushes a rod on the master cylinder, it never touches brake fluid.
the unit itself will work fine with any mastercylinder or pump, as long as it physically adapts (fittings, MC bore, etc). the position of the holes on the firewall and the brake pedal i dont know about.
