hub assembly
Old Dec 3, 2010 | 01:08 PM
454navyss's Avatar
Default hub assembly
does anyone have a hub assembly laying around they could look at for me. i want to know the part number of just the bearings, not the whole assembly. my truck is a 2wd 2002 silverade but i think all 2wd 99-06 GM 1/2 ton trucks use the same hub. thanks
Old Dec 3, 2010 | 01:27 PM
Robert91RS's Avatar
I pulled a new 15946732 hub and got bearing number JRM58000 SF but it is also labeled "do not disassemble". I will also warn that the design has been changed over the years to accommodate multiple applications(ie 2wd & 4wd) so the bearing could have also changed.
Old Dec 3, 2010 | 01:36 PM
00ChevyScott's Avatar
Wearin' da big hat
You can't get just the bearing.
Old Jan 6, 2011 | 08:30 PM
262_NBS's Avatar
The hubs seem to be a non serviceable part. I pulled the dust cover and it looks like the bearing is installed between the spindle flange and center shaft and forged together. You would have to cut the rolled flange apart to seperate the assembly. From what I see the bearing fails due to the small amount of factory grease burning up. It would be nice to find a way to grease the hubs manually
Searching for the Timken bearing PN came up with nothing
Texas5.3_1251
Mar 5, 2016 08:10 PM
blown02408
Oct 1, 2015 01:06 AM
Blklgt
Sep 28, 2015 03:21 PM
sTNT971
Sep 26, 2015 04:22 PM
g6t6o
Sep 26, 2015 10:57 AM
