How much will a stock transfer case take?
I ran N/A for a year with the cam and bolt-ons in the low 14s and never had an issue. I beat the hell out of it launching after the turbo install and it never even whimpered. The only issue is in high TQ applicaitons (600+ft.lbs.) you will have to crank the torsion bars down a bit when racing because the front end will come up off the ground things start gettin hyphy real quick.
I am now doing a swap on the Z71 to an 80E and HD T-Case so I 'll never know the stock limits to the 1500 T-Case.
Originally Posted by thunder550
Do you see any problem with shifting out of 4wd as soon as I start moving? I don't wanna run in 4 hi all the way up into the 90's.
Nope. I used to shift out of 4wd once I started moving and it was fine. After the turbo though it wouldn't shift out so I run 4wd through the whole 1/4.
Originally Posted by kbracing96
I think Parish said he has run his truck in 4-high at 130+
