How much HP can a stock 4L80E take?
Dude thanks a bunch! Now...how built should I have the 80e? Would it handle the 600awhp stock is the million dollar question. I just don't want hard shifts from a shift kit since I'll be carying my family in this vehicle from time to time. Will the softest settings still feel like the stock 65e?
Originally Posted by thunder550
If you get yourself a vacuum modulated pressure control the shifts will be firm but not jarring at part throttle, but will be damn crisp at WOT. That's what I'm running.
Originally Posted by staffcurtis
Can you tell me more about this? How much does it cost?
I am running about 800ft/lbs in our shop truck through a stock 80e with the full performance Transgo kit in it and am having no problems. The strength is there with a Trango kit set at the lower performance level. I actually control the shift feel through the tune. It doesn't have to slam. Also, if you tune with HP Tuners I can hook you up with someone who has the correct segment file for the Escalade. Just PM me when you are ready.
Thanks
I think it can be done but I believe that you would have to change out the T case control module to a selectable 4wd one along with the harness and also change a segment in the pcm programming to respond to the new 4 lo, 2wd, 4wd settings. I thought about it for a few minutes once but it looked like alot of extra work. much easier to just keep it AWD.
Thanks a million!
PS...how do I get up with that company to buy the swap-out 65e-80e stuff?
