How to lineup 4WD actuator on the T-case?
Old Nov 5, 2012 | 05:38 PM
Red99TA's Avatar
Default How to lineup 4WD actuator on the T-case?
So I'm swapping out my transfer case and trying to transfer my old actuator over to the other t-case that I bought. These are both 246s. The actuator is a few degrees off to where I cant get the damn shaft to line up enough to slide it on no matter what I do. The case I pulled it off of locked up so I'm wondering if somehow the shaft was in an abnormal position when I pulled it off the case and now I can't adjust the position of the actuator and its now stuck in this odd position. I tried plugging it back in with the actuator off the t-case and switching between 2WD and 4WD but its not moving at all (not sure if all the different sensors need to be plugged in or not to allow the computer to send a signal to this actuator). I'm afraid of trying to force the actuator into the correct position by rotating the slot a few degrees while the actuator is off the t-case. Any suggestions?
Old Nov 8, 2012 | 11:03 PM
Red99TA's Avatar
Wow...either nobody swaps actuators or they always slide right now without alignment issues?
Pimpinpete
43
Dec 22, 2017 08:13 AM
turbo6c3
Oct 5, 2015 06:11 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
Blklgt
Sep 28, 2015 03:21 PM
sTNT971
Sep 26, 2015 04:22 PM
