How high does your converter flash?
Old Mar 19, 2010 | 06:49 AM
oldred95's Avatar
1500 rpms. Stock 4L80E converter that was behind a 6.5 diesel.
Old Mar 19, 2010 | 10:52 AM
ap2002's Avatar
Originally Posted by GMCtrk
Damn that sounds awesome AP. What stall do you have?
Fuddle converter...
Old Mar 21, 2010 | 03:03 PM
fredkj3's Avatar
4l80e yank 3600 and it flashes to about 3800-3900ish with about 50-60% throttle
same setup as you except i have the cam and 4.30s... yours should be a little looser than that i would think
Old Mar 21, 2010 | 03:06 PM
GMCtrk's Avatar
Do you think it's because of the stock cam? Should it loosen up 500 rpm with the cam? Yours is the 10.5" converter?
Old Mar 21, 2010 | 03:09 PM
00ChevyScott's Avatar
Wearin' da big hat
There's no way it will loosen up 500 rpm with just a cam install.
Old Mar 21, 2010 | 03:16 PM
fredkj3's Avatar
im with 00 chevy.. i dont see the cam changing it that much...
this is what i ordered
YANK PRO TRUCK 3600 4L80E LS1
258mm, Posi Lock-Up Clutch w/Kevlar Linings, 6 bolt mounting lugs , lightweight billet cover, 3600 stall, 2.50 STR LS1
Old Mar 21, 2010 | 03:17 PM
GMCtrk's Avatar
that's the same one I have. Guess mine just ended up tighter the way it was built. Flashing to nearly 4000 must be damn nice.
Old Mar 21, 2010 | 03:19 PM
Wearin' da big hat
The gearing will mess with it some as well.
Old Mar 21, 2010 | 03:20 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Heavy wheel/tire combinations make it flash higher as well.
Old Mar 21, 2010 | 03:32 PM
fredkj3's Avatar
i definetely have heavy rims/tires!!! ha need to get slicks on and go ride around
