How does a flip kit ride?
Old Aug 8, 2007 | 05:57 PM
LowBlack99's Avatar
Only complaint I have on my 4/6 with a rear flip from DJM is if I put to much weight in the bed my tires will rub, had to roll the fender lips as well for tire clearance but I am running of the shelf 20's, better backspacing with a better wheel would eliminate that. As for the ride a bit firmer than stock but I like it that way so I'm happy with it.
Old Aug 8, 2007 | 07:21 PM
Nick99Chevy's Avatar
A 1" lift shackle would fix that if you wanted to.
Old Aug 8, 2007 | 08:42 PM
GTOsRamairSilverado's Avatar
personally i think the belltech flip kit looks like it is much stonger than the other brands, and i think thats the reason its probably more expensive as well.
Old Aug 8, 2007 | 10:43 PM
RandomHero's Avatar
any c-notch is going to be stronger than the 1500 frame as it is so why do you need a stronger notch? Have you ever even heard of someone breaking a bolt in notch(that was installed correctly)?
Old Aug 9, 2007 | 03:31 PM
It's also the only one with a backplate. I went with the McGaughy's because it's almost as beefy as the BellTech and it's about half the price. ALot of people run the DJM notch and have no problems and it's alot smaller than the others.
Old Aug 9, 2007 | 09:50 PM
skyhighsami's Avatar
no title here
I have a full DJM kit and am very pleased. The only problem I have is with my front shocks. I am going to swap out to stockers tomorrow in the front and see if that helps.
Old Aug 9, 2007 | 10:43 PM
It'll probably be worse. LCA's need different shocks, especially 4" lca's.
Old Aug 9, 2007 | 10:47 PM
RandomHero's Avatar
just curious, but do you even have a lowering kit? Do you even know how LCA's work? LCA's don't change ANY part of the coil spring's travel. They're designed to use stock shocks.
I'm all about people having opinions but don't give somebody the wrong advice man.
Old Aug 9, 2007 | 11:15 PM
No, could you please explain since you know everything?
Old Aug 9, 2007 | 11:19 PM
RandomHero's Avatar
Gladly. The spring perches aren't altered at all so the coils still have the same amount of compression and travel. What is altered is the control arm mounts. They're angled depending on the amount of drop you're looking to achieve. So essentially the height of the lower ball joint is altered 4". The spring isn't changed at all.
