How 2 measure pinion angle?
I've been having bad vibrations lately,most people say pinion angle is off.
i went and got my angler finder .
But where do i measure.? is it from the diff and trans/yoke and than subtract.???
any imput links would be helpfull, to find the correct shims and correct my pinion angle..
that link has a TON of info. In dummy terms…park the vehicle on a level ground and measure the angle of the pinion. There are several pictures in the link that bear provided on how to do this. Pinion angle is relative to a level ground with the suspension settled (no jacks or jack stands).
After setting the pinion angle, check the working angles to make sure that your u joints are all within operating range. Done! There are 100 different methods that people go by, so don’t stress out on finding the perfect answer.
Tigger Welder
Oct 1, 2015 08:41 AM
