Hitting OD at WOT?
Old Mar 16, 2008 | 05:30 AM
stock48's Avatar
9 Second Truck Club
Default Hitting OD at WOT?
Is anyone hitting OD at wot? Will it kill the trans? Im running around 5800RPM in Drive un locked at the end of the 1/4 mile. I have 30" tires, and 3.73 gears. Im going to be running 28" slicks at the track, and RPM will be over 6K in drive. My peak power is at 4600RPM, and power dropps off bad after 5500RPM. I thought I could lock up the converter, but it won't hold under WOT so that's out. Can I hit OD at the end of the 1/4 without killing the trans? Thanks J
Old Mar 16, 2008 | 09:52 AM
Truckshop's Avatar
why won't the converter hold?
Old Mar 16, 2008 | 10:51 AM
Last Call's Avatar
TOTM: January 2007
I would not go into driver WOT. I blew my first 4L80e by going WOT on the freeway. I completely shattered the over run/overdrive clutches.
Old Mar 16, 2008 | 03:55 PM
stock48's Avatar
9 Second Truck Club
I guess it's a POS. It will lock up but it slipps like 3-400RPM when locked, under wot. I sure wish I could run the truck locked though, it will hit 17PSI like that and pulls alot harder. I only get 15PSI with the verter un locked. I shift at 5400RPM and it only dropps to 5000RPM un locked. When locked it dropps to 4200RPM which is alot better, but it should drop to 3800RPM locked with a 5400RPM **** point when locked. Yank told me not to lock it under WOT. A precision multie disk is in my future, I don't want to kill my trans before that though.
Old Mar 16, 2008 | 03:56 PM
stock48's Avatar
9 Second Truck Club
Ok I won't do it. I figured it was probably bad.
BROKE-aSS-BLAZER
Oct 13, 2017 03:50 PM
AdaMax
May 16, 2016 11:35 PM
Vortec350ss
Jan 12, 2016 10:36 PM
lukn4trbl355
Oct 21, 2015 11:19 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
