High speed driveshaft help
#21
Thanks for the reply. Then only thing I have left of my tranny failure due to shaft basically is the yoke on the rear end. Of course there was no major failure of the shaft just extreme vibration that removed the rear tranny seal. I will say on the topic of vibration causing fatigue is that after I left the dyno I noticed vibration at around 90 mph with 3.73 gears and I never found vibration up to 120 before that. Might have been a damaged rear bushing on the dyno but I dunno.
Kbracing- your driveshaft lengths in detail would be good cause according to Mark Williams' shaft critical rpm chart, 2" in length can make all the difference in the world in failure speed. I can't see a mid-sized car having more than 55" in driveshaft length? Also, do you know what brand shafts they were running?
gaps
Oct 15, 2015 02:53 PM
