Help w/ 2nd accumulator springs
Old Mar 31, 2008 | 11:02 PM
drag1049's Avatar
Default Help w/ 2nd accumulator springs
Between my vette servo and hd-2 kit, the 1-2 shift knocks your teeth out at WOT, even with NO spacers installed. So I pulled the pan to set the accumulator back to stock, until i realized i forgot what it originally looked like.
I have the original and transgo springs, I want to either set it back to original, or set it up to be a little softer if anyone has a 2nd opinion on the arrangement. I'm just really hoping someone remembers how they are factory.
I know the piston is flipped back over to be factory, I have the blue and orange springs that are installed per transgo instructions, plus another spring that is the same strength as the blue one but about twice as long(no color left). I have all the original springs, but the others I believe are from 4th accumulator, etc.
Tremendous thanks in advance.
Old Apr 1, 2008 | 03:27 AM
KySilverado's Avatar
From my last install. The factory original setup if this helps.
http://i260.photobucket.com/albums/i...o/DSC06539.jpg
http://i260.photobucket.com/albums/i...o/DSC06534.jpg
Old Apr 1, 2008 | 07:16 AM
MS3Z's Avatar
Is that circle in the valve body where the 1-2 plastic accumulator piston is?
Old Apr 1, 2008 | 07:41 AM
Moddoo's Avatar
Yes
Old Apr 1, 2008 | 11:59 AM
drag1049's Avatar
Ky, I worship you like you don't even know.
I have the light blue spring that appears was under the piston, and the green one is the one I have with no color left. It also looks like there's a yellow smaller spring in the center of it, I have a white one that's hard as a brick. I think I'll chuck a spacer under the blue spring so that its a little stronger than stock.
I wish I was smart enough to take more pics than i do, I'm always too messy and in a hurry. Thanks again, I was afraid this might turn into a big fiasco.
Old Apr 1, 2008 | 01:03 PM
MS3Z's Avatar
How hard are they to change, I have an aluminum one that I never used.
Old Apr 1, 2008 | 01:26 PM
Tootall's Avatar
if you have a tune, . . . be sure that your tuner has the line pressure back to "stock" pressure
Old Apr 1, 2008 | 05:26 PM
drag1049's Avatar
The 2nd accumulator is really easy to get to. When you pull the pan, there's 3 10mm bolts right there holding on the cover that you see in KY's second pic. Memory fades on the other piston. It's basic stuff, just really, really f**king messy and not any fun to be laying under it. I still have the plastic piston, not showing any wear, but have thought of changing it.
I have a Nelson tune, but the pressure's set to stock. I actually did the kit before the tune, so I know its just set up that way.
Old Apr 1, 2008 | 06:28 PM
You are welcome. Glad it helped. I do nothing without taking pictures first. I have hundreds from all my mods.
Texas5.3_1251
Mar 5, 2016 08:10 PM
1989k1500
Nov 2, 2015 05:16 AM
zblee
Sep 19, 2015 06:33 PM
Go5.3tt06
Sep 14, 2015 02:11 PM
