Help - tranny drain plug
Old Jun 26, 2007 | 07:26 AM
SSSBLKOUT's Avatar
Default Help - tranny drain plug
I finally grew the ***** to change the tranny fluid (after hearing all the horror stories about the 4L60's dying after that) and I rounded the drain plug trying to remove/drain the fluid. is there a reason, or am I retarded? BTW, that bolt is super tight, WTF??
on a side note, I have an idea or two, anyone got a surefire method for removing this bolt?
Old Jun 26, 2007 | 07:30 AM
Grumpy5.3's Avatar
If it is rounded, just leave it alone, and unbolt the entire pan. We have a hard time with them also, but it will come out with an impact gun and a newish 15mm socket...
Old Jun 26, 2007 | 07:52 AM
truckmann's Avatar
I just used an impact gun on mine and it came out fine. I think it is a self tightening bolt...
Old Jun 26, 2007 | 08:14 AM
Colby 04's Avatar
ha...at least you had one to start with!
Old Jun 26, 2007 | 08:32 AM
ReSpAwN DeMoN's Avatar
I rounded mine off as well...
I ended up dropping the whole pan to change the fluid anyway... its ok though.. my tranny died 3 days after the change. (I figured while I had the pan down I would go ahead and install a shift kit.. and while under the truck I decided to install the servo's..
Old Jun 26, 2007 | 10:13 AM
Tootall's Avatar
no kidding, I bought a after market deep pan, and it came with one.
Old Jun 26, 2007 | 10:39 AM
WJ MARK's Avatar
yup same here. I installed my tranny temp sensor when I did the stall, shift kit and servos, so atleast I can pull the sensor and drain it that way.
Old Jun 26, 2007 | 12:56 PM
SSSBLKOUT's Avatar
well, I was gonna drop the pan and change the filter as well, but in order to do that,
I have to remove the ORY, and to do that, I have to drop the tranny crossmember. I guess a deep pan is in order now.
I rounded it with an impact gun, that damn bolt is so shallow, theres hardly any contact area.
I think I am gonna cut a slot into the head of the bolt and get it out with the flat head breaker
Old Jun 26, 2007 | 01:08 PM
bluecajun5.3's Avatar
11 Second Truck Club
were you using a metric socket?
i've heard that some deep pans do not clear ory's
Old Jun 26, 2007 | 01:40 PM
Tootall's Avatar
I've got a TCI pan and it clears, or did while I had it.
Put a pipe wrench on it and try that.
