Help With Lowering An 07 Nbs 4x4 Crew
Old Jul 10, 2007 | 10:31 PM
my black ss's Avatar
Default Help With Lowering An 07 Nbs 4x4 Crew
HELP WITH LOWERING A 07 NBS 4X4 CREW .........I know the rear is extremely easy remove blocks and install 2 inch shackles together =4...But the front is coil over. And i dont know if I should use springs or if I should use droped lower controls....And will the 2wd ones work or not really hope you guys can help me out with this thanks josh.....
Old Jul 11, 2007 | 05:29 PM
TTT. anyone
Old Jul 11, 2007 | 06:57 PM
Allgonoshow's Avatar
mine is 2wd, xcab
i put belltech 2" spindles on the front and belltech 2" shackles on the rear as well as removed the spacers.
there seems to be little difference in 2wd vs 4wd, belltech doesn't list different part #'s but mcgaughs does,
oe design differences are most for spring rates and shocks as related to load rating
but setup is the same
spindles are preferable for ride quality and steering geometry
http://www.belltechcorp.com/download...guide_2007.pdf
Old Jul 13, 2007 | 10:38 PM
Talked to belltech today 2inch front spindles for the 4x4 are only...$260...But they want me to run a flip kit and a 1 inch shackle to get the 4 in the back really dont want the flip kit with as much as i tow. I am just gonna remove the rear blocks and run a 2 inch shackle **** the flip kit
GXPJAY
Feb 13, 2022 08:15 AM
Abuckeye
Aug 19, 2015 06:11 PM
Nimoryan
Jul 5, 2015 03:50 PM
