Help choosing dif gear ratio for my setup
Old 11-11-2018, 12:47 PM
400ss's Avatar
Default Help choosing dif gear ratio for my setup
Hi all, not a gm truck but driveline is GM tho.
Its a 1994 F150 lightning.
-GEN4 5.3L
-Procharger D1 14-15 PSI at 6200 RPM
-Meth injection
-91 oct fuel
-6L90E transmission
-im dialing in the tune but currently truck is doing 12.7 on 1/4 mile
-Currently truck has the stock 4.10 gear ratio.
-Running 28/10/17 Hoosier tires
What would be a better or correct diff gear ratio for my setup?
thanks
Old 11-11-2018, 02:06 PM
How’s it running with the 4.10? Does that make the first gear to low? I know the stock trucks using that trans have like 3.42 rear gear. You getting to the OD gears in the 1/4? Rule of thumb in the 1/4 is you end up redlining in your 1.1 trans or 4th gear in yours which is 1.15.
400ss (11-11-2018)
Old 11-11-2018, 04:18 PM
400ss's Avatar
Fisrt time i took it to the track it did 13.1, installed the converter and it did 12.9, it was hitting limiter on some shifts, the last time i took it to the track i did some work on the trans tune and it shifted good, it did 12.7, but on the logs i can see it shifts to 5th gear before the end wich means it is shifting to OD gear... on the street 1st gear is pretty much useless to be honest, i can make it start from 2nd gear for daily but i im interested more in the correct gear ratio for the 1/4 mile, should i go 3.73 or 3.55?
thanks for your time, apreciate it
Old 11-11-2018, 05:00 PM
madmann26's Avatar
I would put a 3.23 in it. 4the will much more usable.
400ss (11-11-2018)
Old 11-11-2018, 09:25 PM
400ss's Avatar
whats the stock gear ratio on 5.3l/6.2L with 6l80e trucks?
are you positive it will be an improvement? 3.23 makes me think it will be super slow out of the hole? 6l80e has high gear ratios right?
Old 11-11-2018, 09:46 PM
FFDP's Avatar
3.42's are stock and I think the max towing package got 3.73's.
When they went to the 8 speeds it switched to 3.23 and 3.42 with max towing.
400ss (11-11-2018)
Old 11-11-2018, 09:53 PM
400ss's Avatar
more suggestions? im not sure wich one to use
Old 11-12-2018, 08:34 AM
randeez's Avatar
what mph are you at? 106ish?
3.73 would be more fun on the street but if you turn it up much more you're going to be back running out 4th gear in the 1/4.
id say 3.55 or even 3.42
3.55 with 28x10 should be real close to my yukon with 4.10s and 32" tire as far as final ratio. mine traps almost 103 would have to look at a log to see actual rpm tho but it's comfortably in 4th 5600rpm+
with 3.42/32" i would run out 3rd and trap around 100-101 with shifts set at 6500 though
Old 11-12-2018, 09:55 AM
400ss's Avatar
nice thats goof info, i dont plan to race the truck on the street because of traction, i would love it tho lol, yes it was at 100-106 i will double confirm on the log, i plan to now run E85 and push it a little more, if a blow the engine, next step will be stock crank, forged rods ans pistons, keep same setup, maybe litle more boost and maybe a small nitrous shot, wich one would you run 3.55 or 3.73? cant decide? will update with pictures and couple of logs, thanks everyone
Old 11-12-2018, 05:22 PM
FFDP's Avatar
Just do the math to help you decide, we've kinda already said what mph you'd be at with a certain size tire.
Look up one of those online calculators that you can put tire size, engine rpm, rear end gears and transmission ratios to help you pick the perfect gear ratio.
It's likely that you need to stay around 3.42's so you can be in 4th gear all the way through the end of the 1/4 mile.
Quick Reply: Help choosing dif gear ratio for my setup
