hello all anyone know the strongest ring and pinion gears for a 8.5 10 bolt?
ive broken 3 sets of the motive performance gears 2(4.56) 1(4.10) the 4.10 being the most recent. looking for some insight on the best/strongest brand so my ring can last i heard the numerically lower you go the stronger is that true?.... truck has moser axles, true trac,
https://cimg2.ibsrv.net/gimg/www.per...4ad3cb237f.jpg and a girdle cover everything else is fine just the ring gets destroyed, im gonna attach some pics from the weekend of my ring from the track i was on drag radials Truck is boosted for more info! https://cimg3.ibsrv.net/gimg/www.per...2e7c213120.jpg |
You hit it with a trans brake or something? I figured the factory GM ones or maybe the Yukon gears were strong enough.
Originally Posted by Three6GMC
(Post 5434892)
IMO, AAM gears are the best.
I have seen that before on motive gears. https://www.performancetrucks.net/fo...nd-pix-473409/ |
There are differences in the size of the gears based on gear ratio. The lower the gear (higher numerically), the smaller/thinner the gearset will be.
Then you have thick cut gears, offset and thin cut gears. |
Gears
I ran Richmond gears in my race/street cars for years
and always had good luck with them. |
I think I may try to run Richmond |
Might have the gears cryo'd also.
I had AAM 4.10s in mine. Help up to power. Moser axles not so much, twisted up. Stock axles were stronger.
