Grind and pop in front end?
Old Nov 20, 2008 | 06:09 PM
2ktransam's Avatar
Default Grind and pop in front end?
I have been hearing a grinding sound in my front end lately on the 1-2 shift in 4wd. Then tonight I was doing some tuning and while I was stalling up the turbo in 4wd I heard a grind and pop in the front end without moving so I let off and came home. I couldn't see anything wrong so I took it back out and hit the 1-2 shift in boost and I heard a grind and pop but it stopped very quickly and drove fine. What could this be? It doesn't have any problems in 2wd only in 4wd.
Old Nov 20, 2008 | 09:05 PM
2ktransam's Avatar
Anybody got any ideas? I'm supposed to be racing on Sunday and I don't know if I should now.
Old Nov 20, 2008 | 09:56 PM
jake 03's Avatar
sounds like a carrier bearing to me,I wouldn't push it in 4wd until you get it checked out.
i would pull the plug on the diff and drain the oil to see if there is any metal in it.Evan if there isnt I wouldnt push it just because that isnt the strongest frontend on a good day and if its making noise and you break it at the track you will go home behind a wrecker.IMHO
Old Nov 20, 2008 | 10:02 PM
2ktransam's Avatar
Any clue on how much it would cost to replace the carrier bearing? Sounds expensive.
JordanH
Feb 28, 2017 07:22 PM
Corvette454l88
Sep 1, 2016 01:24 AM
5.3Caprice
Nov 7, 2015 08:56 PM
vmaxpro
Aug 10, 2015 07:25 AM
Offroadunleashed
Jul 20, 2015 02:25 PM
