GMT 900 Belltech 2/4 Drop rubbing
Old Aug 26, 2018 | 01:08 PM
dsmmace's Avatar
Default GMT 900 Belltech 2/4 Drop rubbing
I just finished installing my beltech 2" Drop with Spindles and 4" Rear with Shackles and Rear Axle Block Removed. It rides fantastic! Way better than I expected to be honest. Maybe the Rear Hellwig Swaybar helps too.
The problem I am having is the front tires are rubbing on the inner fender when turning at close to full lock. It's bad enough I have removed my front mudflaps and it still rubs. Is there anyone else that had this problem with factory sized tires?
Old Aug 26, 2018 | 06:38 PM
FFDP's Avatar
Yup.
My almost 2in front drop rubs my mud flaps very close to full lock. They don't rub hard enough to rip them off so I just let it rub and stopped caring. I've run 2 different sets of 265/65/18 factory tires and it's the same on both. A smaller tire or different rim spacing would likely fix the issue.
Turbo09
Mar 13, 2017 05:31 AM
iamkeniff
May 15, 2011 12:36 PM
lowoh8
Oct 17, 2010 03:51 PM
5.3AlmnBlk
Sep 30, 2005 02:13 PM
GoldenVelvet
Jul 25, 2005 11:27 AM
