Gear swap
Old Oct 21, 2007 | 10:04 PM
colekill's Avatar
KickinAssAndTakinNames
Question Gear swap
I want to move up to some 4.10's or most likely some 3.90's.
How hard is it to do the swap your self? Dose it just mean taking off your differential cover and swapping them out, or is there much more to it? Would you suggest taking it on or taking it to the shop and spending around a grand?
Old Oct 21, 2007 | 10:17 PM
skyhighsami's Avatar
no title here
Pay someone to do it. Installation is pretty ease the proper set up is what is so hard.
Old Oct 22, 2007 | 10:15 PM
Bo185's Avatar
What gears do you have now?
If you have 3.73 and you are 4x4. I wouldn't waste the money unless you go to 4.30's the difference isn't much and will reduce you MPG as well.
I don't think you will gain much for the cost of the swap even on a 2wd unless you have 3.42's. Just get a Limited slip or locker! And have someone do it.
Old Oct 22, 2007 | 10:22 PM
colekill's Avatar
I have a 99 2wd. It has a limited slip diff. from the factory and 3.23's
Old Oct 22, 2007 | 10:29 PM
TouchOfEvil04's Avatar
If your rolling 3.23's for gods sake get some gear behind it. Also i say get someone to do it for ya as well.
Old Oct 22, 2007 | 10:38 PM
Moddoo's Avatar
What he said.
4.10s will rival everything else you have done to it.
Get a Detroit True Trac while you are in there.
Old Oct 22, 2007 | 11:13 PM
colekill's Avatar
how much should i expect to pay for all that. the 4.10's and Detroit True Trac?
Old Oct 23, 2007 | 12:43 AM
ZZebes's Avatar
i agree with above
i went from 3.23's to 4.10's and i dropped a second off my quarter mile times and picked up a few MPG's
best mod ever
also, pay a shop, your dealing with tolerances down to a thousandth of an inch
Old Oct 23, 2007 | 02:28 AM
chuckie311's Avatar
600 to 700 depend on what gears you get
Old Oct 23, 2007 | 09:29 AM
colekill's Avatar
I thought 4.10's were supposed to drop your MPG by 2 or 3 miles. That’s why i was thinking about the 3.90's better than 3.75's but not as extreme as the 4.10's.
How much should i expect to pay??
