Gear Pattern 14 bolt SF
Old Aug 31, 2010 | 03:47 PM
Beatdown Z's Avatar
Laid Back
Default Gear Pattern 14 bolt SF
I'm setting up my 14 bolt semi-floater and want to see what you guys think of my pinion depth.
Here's with .030" shim and .007" backlash:
Old Aug 31, 2010 | 03:49 PM
Beatdown Z's Avatar
Laid Back
And here's with .002" added to the pinion shim, backlash still at .007".
Atomic's Avatar
I have a gauge for that
Looks pretty good, if not a little too much on the pinion shim. I wouldnt have a problem driving those.
You are going the wrong direction in the second set. Try 0.0275"
Old Aug 31, 2010 | 03:50 PM
Beatdown Z's Avatar
Laid Back
Soooo, run the first pattern, second pattern, or in between(.031" shim)?
Old Aug 31, 2010 | 03:54 PM
Beatdown Z's Avatar
Laid Back
I tried .027" and it moved the pattern too far towards the face/outside of the ring gear. I have pics of it, but I don't want to clutter the thread with too many pics.
I added the .002" to try and center the coast side a little better, but it changed the drive side more than I thought it would...
Old Aug 31, 2010 | 03:56 PM
Atomic's Avatar
The 0.030 looks better than the one with more shim. You want the thick part of the contact to be as close to the center as possible.
Dezert1500
Jul 30, 2015 02:51 PM
iregret
Jul 27, 2015 10:31 PM
EscaTruck
Jul 20, 2015 11:42 AM
Blackrat48
Jul 8, 2015 05:28 PM
