GEAR ME, help please.
This is what i have come up with on what i have.. so please chime in..
2001 chevy sububran 2500 4x4..
front would be 9.25 Reverse cut IFS gear set?
Rear would be 10.5 and its a 14 bolt
Im assuming that because i have 3:73 stock gears that my gears will need to the "thick" ones..
What i want to do is 4:56 gears with a limited slip up front...
( Jegs has one listed Powertrax No-Slip Traction System Steel GM 9.25" IFS 33 Spline) If that will work..
Then in the rear a 4:56 gears and a locker...
Im running 35's on 16 inch wheel and truck is some where around 700 hp and god only knows on torque....
So those of you that know more than i do, does that sound correct on axle size... its also a 373 stock gear.
I would without a doubt contact Ron's Machining Service and tell him what you are doing. He will have the best prices, and is the most knowledgeable person on the subject.
RONS MACHINING SERVICE Home Page
jtphelps289
09-29-2015 12:00 PM
