G80 Problems!!
Old Mar 26, 2008 | 01:50 PM
suzukibruce's Avatar
Default G80 Problems!!
i have an 03 silvy std cab short box 1500 5.3 ls 2wd.... the rear keeps locking and unlocking in turns and makes a terrible noise doing so....i'm thinking just replace the whole rear since i have no idea how to rebuild one (taking it to someone is not an option... i like to do my own work!) but i figure what the hell if i rebuild it myself than i'll know how to do it! now heres my question... has anyone else had this problem? is it an easy fix? (as compared to rebuilding a motor) what parts do i need, what to look out for, can it still be driven like this or will i totally f@#$ it up? can i just replace the factory locker with an aftermarket one? what am i getting myself into? thanx for all your help it will be greatly appreciated!
Old Mar 26, 2008 | 02:44 PM
fastnblu's Avatar
Check your other post too. Wonder if the NOS if helping any? Let us know what u decide.
Old Mar 26, 2008 | 03:41 PM
joshua022's Avatar
Its supposed to be unlocked during a turn or else the tires will chirp.
Old Mar 26, 2008 | 03:45 PM
"the rear keeps locking and unlocking in turns and makes a terrible noise doing so"
Old Mar 26, 2008 | 03:53 PM
BOSS302's Avatar
ditch it before it blows...get a tru-trac and be done with it. Mine blew 2wks ago and took the tranny w/ it...04 w/ 47K miles
Old Mar 26, 2008 | 04:00 PM
truckmann's Avatar
If you are going to do it yourself I sure hope you can find someone that knows what they are doing to help. While setting up gears is not rocket science it can be a pain to get right and if you don't get it right you will be cursed with the dreaded gear howl or worse.
Old Mar 26, 2008 | 05:06 PM
fastnblu's Avatar
Same here, had my 89 rear go, also fryed trans w/it. 2x the expense.
Old Mar 26, 2008 | 05:59 PM
blue 01's Avatar
My dads did this. It just need to be cleaned with some brake cleaner. Then put new oil back in it.
Old Mar 26, 2008 | 07:01 PM
nonnieselman's Avatar
i decided to just put a Eaton in mine before the G-80 blew....
i got lucky and was able to just reuse the factory shims and everything was exactly back to spec....
Old Mar 26, 2008 | 07:38 PM
fastnblu's Avatar
Did what? What suzukibruce had happen? Or what BOSS302 & myself had? Cause for me, my 89 has movement inside rear (front/back, side-side & up/down. Have over 176k miles, prolly original rear, but who knows? If so, its due. And, snapped input shaft in 2, destroying my built trans. My 89 showed me how strong a 700r4/4L60e is 1 bone stock, 2built. - the G80 is better by some measure. I hope on the 04 I can get Eaton before I find out. I want a FLT 1st tho.
Suzukibruce, any news?
