G80 blew this morning and took the tranny w/ it.
Old Mar 26, 2008 | 08:25 PM
fastnblu's Avatar
Originally Posted by BOSS302
I talked to the tech, he's put 7 new G80's in half tons in 2 weeks.....I guess it was kind of a blessing in disguise cause the tranny was startin to slip in the 1-2 shift. I was planning on a FLT lv5 4L65E this summer, but I might wait a little bit now.
BOSS302, was that on 04 in sig? Care to talk to my dealer about my soft 1-2 shift,...or is it 2-3? Wonder if I should remove tune 1st, along w/ headers back, & CAI. I wouldn't remove all my stuff unless they said that was only way, but at that point, they know how u drive. Oh well, I'm screwed since I have 47k on truck, right?
If that is a brand new truck, that's scary. That would mean they're a bigger than b4.
Old Mar 26, 2008 | 08:44 PM
fastnblu's Avatar
Originally Posted by Mr. Sandog
Let this be a warning to anyone who thinks they can eek by with the Grenade-80 while increasing horsepower and tire size.
Now that's funny there(Grenade-80). Tire size will do it as well?
Originally Posted by WillPewter2000
Been there done that. Mine happened on the track still had reverse but no foward drive gears.
Originally Posted by parish8
i ran a 10.08 at 136 with mine. then kyle(1320video) blew it up doing a burn out at a rest stop 50 miles from home.
Ya, Will, on my C/K. To u both, & others. I usually find the weak points when I do the stupidest things. On the C/K w/167k miles, 1 day after I did a braketorq, I was on xway in heavy traffic. Motor blew. Replaced w/ more power. Blew stock 700r4, blew 1 built 60E, & grand finale:Blew rear & another built 60E together screwing around. Nowhere near Jim's HP/TQ!
Old Mar 26, 2008 | 08:46 PM
95 bright teal's Avatar
The 4l60e shifts really soft in these trucks, until you swap to a corette or super servo. fastnblu your tranny is probably fine, if its slipping it would act differently.
what kind of tune do you have, that can creat a warrenty problem, but basic bolt ons will not. i hope this helps
Old Mar 26, 2008 | 08:49 PM
oh and suzukibruce you shouldnt need a new rear there are many high horse power truck running that rear end, you need a new locker(non-g80) and maybe some new gears and you will be set
Old Mar 26, 2008 | 09:11 PM
BOSS302's Avatar
The 1-2 shift on the 4l60 is sloppy anyway, and the only way to somewhat remedy it is w/ a vette or billet servo, or a shift kit (transgo HD2). The 10 bolt can take plenty abuse and power and still keep on goin, it's the G80 Gov-Lock that is the weak link in the chain, it is the nature of it's design. Under low power engagement it will last for a long-time, but if you really get on it.... My tranny was slipping a bit, even w/ increased line pressure and a vette servo, and thats because I bought the truck when I was 17 and drove like it. The rear-end blew and cracked one of the planataries...GM determined this was caused by the abrupt seizure of the G80, thus overstressing...yada, yada, yada. Your trans is probably fine, just don't race every honda you see at a red-light.
If you drive hard, ditch the G80 for a tru-trac or Eaton LSD, the factory ring and pinion should be fine, many guys are running them in high power trucks. Do the servo install, your transmission will thank you. BTW, a tranny cooler is a definite must have.
Dustin
Old Mar 26, 2008 | 09:22 PM
boss302 is gm going to fix yours?
Old Mar 26, 2008 | 09:25 PM
BOSS302's Avatar
actually yeah...5yr/100,000mi powertrain, it kinda helped to know the GM of the dealership....im gonna order a tru-trac and 4.10s in the next few weeks, cause i'm not goin through this again.
Old Mar 26, 2008 | 09:30 PM
nice! yeah im getting ready for a trutrac, definatly dont want to go through that. well it good to here you were covered!
Old Mar 26, 2008 | 09:38 PM
BOSS302's Avatar
yeah..i'm picking it up from the dealer, then driving to my buddies shop to put the tru-trac in...i just picked up a set of OEM 4.10s w/ 230mi from a guy who lifted and put 4.88s in..$50 was all he wanted...haha
Old Mar 26, 2008 | 10:03 PM
fastnblu's Avatar
I said soft, I misspoke, slip(s) prolly is the right word. Didn't do it when I 1st got tune. Local did it so I could dyno it, got rid of speed limiter, tq mgmt. That doesn't help , nor did more mods, or driving it hard! Thanks for input.
Dustin
Ya, I don't exactly drive it easy. I hit it any time mood strikes, a bad idea for longevity. That stuff is coming...& more. I can't afford trans, @ this time, so parts sit until the day comes. But then...
colekill
14
Oct 11, 2016 11:56 PM
Corvette454l88
Sep 1, 2016 01:24 AM
Goat's ss
Jan 3, 2016 06:28 PM
bighouse
Sep 27, 2015 12:37 AM
Mossyoakglock
Jul 17, 2015 08:30 AM
