full size SUV guys (suspension)
Old Oct 10, 2009 | 06:53 PM
TURBHOE's Avatar
Originally Posted by AKlowriderZ71
Could probably find some poly bushings for cheap.
still looking for some. i do like the grease fitting of the aftermarket ones. i hate how poly's squeak if not lubed good.
Originally Posted by supersub
the Lower control arms increased the firmness in the ride. Noticable around turns I believe the stock lowers flexed allowing some give with the black rated springs. Also the footprint from both tires are now consistant with ea other. the 1.8 are from 4wd but i do believe there is also lost energy from the upward movement vs. leaving forward. it leaves evenly now. I have not been down the track yet with the new combo.
I am looking into some alternatives in this department(shocks) as well.
so the arms made it launch straighter too? mine twist hard to the left when it comes off the line. it would always unload the front right tire real bad when awd.
Old Oct 10, 2009 | 06:58 PM
supersub's Avatar
Yep! Now if i can just keep the front down!
Old Oct 10, 2009 | 07:03 PM
TURBHOE's Avatar
some guys put wooded blocks between the upper control arm and the little lip below it. others have bolted straps to the frame and lower control arm. it would suck for a ride around town but ok for track.
Old Oct 10, 2009 | 07:12 PM
TURBHOE's Avatar
so how much closer is the 14bolt cover to the panhard bar than the 10bolt cover? and do you think the 14bolt would benefit much from a girdle cover?
Old Oct 10, 2009 | 07:42 PM
TURBHOE's Avatar
what about the short panhard bar about half way down. http://www.timskelton.com/lightning/...on/panhard.htm
Old Oct 10, 2009 | 07:44 PM
supersub's Avatar
the girdle cover won't fit with the pan hard bar, I have about 3/8" from the stock cover.
its a real tight fit.
Old Oct 10, 2009 | 07:56 PM
TURBHOE's Avatar
i looking more into why the edelbrock tubular panhard rod wouldn't fit. could a person build one from thick dom tubing and bend it around the cover where needed. then put gussets in the bends?
Old Oct 10, 2009 | 08:10 PM
supersub's Avatar
Now thats a good thought! i could be up for that.
Old Oct 10, 2009 | 08:52 PM
TURBHOE's Avatar
i seen a few aftermarket ones for other cars like that, which is why i ask. i figure you would want a thicker dom tube than a car. but with a good gusset, it should be strong and could use stock mounting points.
Old Oct 10, 2009 | 09:16 PM
TURBHOE's Avatar
not the best show and tell but found this one so far. http://www.4x4wire.com/isuzu/reviews...n/calsus5s.jpg
