Front end replacement parts, is Moog the preferred brand?
Old May 27, 2013 | 05:25 PM
BlackGMC's Avatar
Resident Retard
Default Front end replacement parts, is Moog the preferred brand?
I am going to be replacing my entire front end suspension parts in a few weeks i was wondering if Moog was the preferred brand.
Also should i replace the inner tie rod ends?
Old May 27, 2013 | 08:28 PM
Suburbazine's Avatar
Moooo....
Yes MOOG is the OE quality stuff. Anything not a MOOG is a lesser part. If you're replacing everything, I see no reason to pass up the inner rod ends either.
What I do recommend is cryo-treating the high stress parts like the pitman arm. I've had good luck keeping them tight longer after treatment.
Old Jun 1, 2013 | 01:41 PM
72te27's Avatar
Moog used to be a sure bet. Nowadays, shop Moog carefully.
Raybestos Professional Grade is higher quality. It is also boxed as Carquest Blue.
Old Jun 1, 2013 | 02:53 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
I use the Raybestos (Carquest Blue) chassis parts more than anything else now.
Old Jun 1, 2013 | 03:40 PM
53RUSSELL's Avatar
Corey,
I just did my front end and found out it was cheaper to buy the whole control arm than buy each each part to replace existing parts. I used Napa part and it cheaper by $30 to $40 depending. Side not i had a hard time finding the right bushing for the lower controller arms and ball joints in the lower control arm a bitch to take out.
Old Jun 1, 2013 | 04:00 PM
BlackGMC's Avatar
Resident Retard
Interesting. I don't know if there is a NAPA around here. I might need to check them out online.
mzoomora
Jan 3, 2016 07:06 AM
Ketis
Jul 23, 2015 12:37 PM
Offroadunleashed
Jul 20, 2015 02:25 PM
jmarkway
Jul 18, 2015 09:23 PM
black6spdz
Jul 16, 2015 01:32 AM
