Front Differential Problem
Old Jul 14, 2008 | 07:46 PM
KevinF56's Avatar
Default Front Differential Problem
so i discovered this weekend that my front differential is leaking where the CV and diff meet on the passenger side. i assume there is a seal there that might just be leaking? is it as easy a fix as pulling the diff, pull the CV and replace the seal?
also, the way i discovered this problem is that when i turn left (so it puts weight on the right side) i hear a kind of clicking sound. i assume this is the CV making the noise. could this be because of the bad seal?
Old Jul 14, 2008 | 09:29 PM
KySilverado's Avatar
Assuming where the half shaft meets the diff? If so yes its the seal in the end of the diff. I replaced mine about a year ago. Common from what I've read. No clicking with mine. Just noticed the oil slinging.
I left the diff in the truck. Removed the long side axle tube. There was a trick getting the axle out that I don't remember... but no biggie. Also some springs that you have to pay attention to and get back in correctly.
Old Jul 14, 2008 | 10:06 PM
KevinF56's Avatar
ok me and GMracer might attempt to remedy it. do you have a part number for the seal?
Old Jul 14, 2008 | 10:09 PM
Sorry don't have the part number for the seal. You'll also need some of the special red sealant to put the tube back on.
Old Jul 14, 2008 | 10:19 PM
KevinF56's Avatar
ok i'll check into it. thanks for the tips.
Corvette454l88
Sep 1, 2016 01:24 AM
Turk55
Sep 11, 2015 11:52 AM
Wareagle23
Aug 8, 2015 10:06 AM
Jake99
Aug 8, 2015 07:56 AM
