FLT.lvl 5 took a crap
Old Dec 12, 2009 | 11:59 AM
  #21
WJ MARK's Avatar
I was going around a big truck that wasn't moving and hit some gravel, tires spun then got pavement and boom. I was probably only going 20-30 mph when it happened.
  #22
built408's Avatar
Originally Posted by kbracing96
Do you still have reverse? This is what mine 65e kept doing and only reverse would work. Wasn't a hard fix, but still have to pull the trans and all the guts just to change them out.
wow, I've never seen a shaft break that clean before.
Old Dec 12, 2009 | 12:18 PM
  #23
kbracing96's Avatar
The first one is the one on the bottom with the twisted splines. It is also cracked thought the oil hole in the bearing in the middle of the shaft. It broke while brake stalling to 8psi for a 4x4 launch. The top one broke at the LS1truck.com race day at SAR last Feb on the 1-2 shift at 13psi. The only thing I can think of why they where such clean breaks is they are GM cryo treated shafts for 08 TBSS 4x4's 4l70e.
Truck got the 4l80e after that. Oh and that 4l65e tranny those broke in, is currently in a 408 NA F-body running 10's with nothing more then swapping a 2wd shaft in it after the second 4x4 one broke,
Old Dec 12, 2009 | 01:01 PM
  #24
southern_chevy's Avatar
same thing pop and nothing and no burnt fluid on a 4 month old trans
Old Dec 12, 2009 | 01:33 PM
  #25
trever1t's Avatar
2nd fastest 5.3 ECSB
Originally Posted by WJ MARK
Are you still rockin the FLT 65e????
Yes, I feel blessed it has held up so well for me, I know I really need an 80e in there but $ and time but mostly $, ya know. I do have the hardened input/output shafts.
ouch....
Old Dec 12, 2009 | 02:16 PM
  #26
silver-mod-o's Avatar
Hunt&Fisherator
Sounds like an input shaft if the trans will still hold in park??
Old Dec 12, 2009 | 04:51 PM
  #27
stevenc's Avatar
Lets hope you didn't do one of these:
I broke it going from a cloverleaf on the freeway to the next freeway, gave it some gas to get out of the way of a semi, and hit the rev limiter.
My guess is input drum or shaft.
Old Dec 13, 2009 | 12:52 AM
  #28
WJ MARK's Avatar
yeah im pretty bumbed about the whole thing, really couldn't be worse timing. I have even skipped going tho the track all year so i wouldn't have any break downs
Old Dec 13, 2009 | 01:03 AM
  #29
budhayes3's Avatar
PT's Slowest Truck
That stinks, you try to be cautious and do the right thing and still end up screwing the pooch I'm definitely glad that I'm springing for the Level7 with the billet shafts, I've seen more and more pics of trashed shafts...
Old Dec 13, 2009 | 01:04 AM
  #30
Daryn's Avatar
Formerly darynC-10/23/10
4 months old?? well **** that should be under warranty then. if not ,sell that pile and get a junk yard 80e
