Finding a used 3.73 limited slip diff, what to look at?
Old Aug 14, 2011 | 10:17 AM
BlkNight02's Avatar
Default Finding a used 3.73 limited slip diff, what to look at?
I'm started to look for a diff that has 3.73 and limited slip setup and need to k ow what to look for (visually) for the right one. What are the specs on a g80? Will the newer drum brakes year interchange with the early disc brakes backing plate fir the housing? And axles lengths are the same in all 1/2 ton Chevys from 99-06?
Old Aug 14, 2011 | 10:30 AM
greenturtle05's Avatar
Axles are same length. only two ways to tell is by looking at the code in the glove box and or pulling the diff cover off. just look to see if it has clutches in it.AFAICR
Old Aug 14, 2011 | 07:11 PM
BlkNight02's Avatar
I only have about 500 to 600 $ to spend so
Old Aug 14, 2011 | 09:10 PM
Are you looking to buy an aftermarket carrier or a stock g80?
Old Aug 15, 2011 | 11:18 PM
BlkNight02's Avatar
I am looking for the entire axle housing ***. With 3.73 and limited slip and later I will change to detroit trutrac. To rebuild everything ( axles, gears, bearings , seals, and truetrac) would run me around 1200 for parts
5.3Okasai
Mar 9, 2022 01:07 PM
fastjweb
Aug 15, 2015 10:47 AM
Dezert1500
Jul 30, 2015 02:51 PM
So.cal Wrk Sled
Jul 26, 2015 12:10 AM
Ammadien
Jul 22, 2015 08:50 PM
