Finally!!! Hell yeah
Old Mar 11, 2008 | 06:27 PM
regency's Avatar
Default Finally!!! Hell yeah
time to step it boys
www dot rosslertrans dot com
Old Mar 11, 2008 | 07:38 PM
bluecajun5.3's Avatar
11 Second Truck Club
what u gonna do with that.
thought you couldn't catch traction already?
Old Mar 11, 2008 | 07:43 PM
joshua022's Avatar
I don't know much about trans brakes, could I get one of them instead of a bigger stall? or will it only brake up to what the stall is rated for?
Old Mar 11, 2008 | 07:46 PM
maddboost's Avatar
It stalls up to the stall speed on the brake which can be higher than you can foot brake a converter.
I wouldnt recommend a 4L60E with a trans brake in these trucks, the weight of the truck for the transmission to move is already asking a lot, I would recommend upgrading to a 4L80E if you are really dead set on a trans brake.
Old Mar 11, 2008 | 07:49 PM
joshua022's Avatar
What about a built 4l60 from say FLT or performabuilt
Old Mar 11, 2008 | 08:03 PM
Klive's Avatar
Banned
NO
there have been guys that have used the transbrake 4L60E but I havn't seen any that use them in the trucks. I say its a ticking timebomb to ask an already weak transmission to slam into first gear and try to sling 4500ish# out of the hole.
Old Mar 11, 2008 | 08:05 PM
67SS509 has one.
don't know if he's used it yet.
mods:
2002 Silverado scsb 2wd- LS7-427 cu.in. 12.5cr, ETP heads w/2.20" ti valves, Jesel shaft rockers (1.8), CompCam 242/246 .642/.649 112LSA+2, Kook's 1-7/8" headers, Magnaflow X-pipe, 44lb/hr injectors, Yank3600, FLT/5+ 4L65E w/Rossler transbrake, 14bolt w/4.11, eaton, CalTracs, Denny's driveshaft
Old Mar 11, 2008 | 08:10 PM
JJ_TURBO's Avatar
I have one, but an a level 5 80-e from FLT, I will have new results as soon as I get it back in, cause I had some problems with the converter.
Old Mar 11, 2008 | 08:48 PM
maddboost's Avatar
Call and Talk to Vince or Chuck at FLT and I bet you couldn't convince them to put a brake in a 4L60E in a truck.
Old Mar 11, 2008 | 08:59 PM
regency's Avatar
me no no no i get great traction!!! just not on the street...lol
