Fbody 60e in a silvy?
Old May 3, 2011 | 12:53 PM
chubbz817's Avatar
Thanks for you help guys I really appericate it
So I just get the tranny bolt it up an get a drive shaft and I'm done I'm I understanding this correctly?
Old May 3, 2011 | 01:27 PM
budhayes3's Avatar
PT's Slowest Truck
Sounds like all you need is the tailshaft housing (which was my assumption as per our PM's but I wasn't sure so didn't want to lead you the wrong way )
How about the torque converter, will the f-body verter work too?
Old May 3, 2011 | 01:36 PM
Andy @ FLT's Avatar
Banned
don't forget the linkage bar will have to be changed because the truck has the external switch and the f body does not. Like I said it's not a big deal.
Old May 3, 2011 | 01:46 PM
budhayes3's Avatar
PT's Slowest Truck
How about the torque converter Andy, are all LS/60E converters a direct swap?
Old May 3, 2011 | 02:33 PM
chubbz817's Avatar
Yea how bout the converter will it work?
Old May 3, 2011 | 02:53 PM
RoadKill03's Avatar
it will work, the only thing you need to swap out is the shifter lever shaft. f bodies have a short shifter lever shaft and trucks have a longer one because the trucks have the safety neutral switch installed there and f bodies don't
Old May 3, 2011 | 03:00 PM
ls1stang's Avatar
I have done the swap and other than the shift arm its a direct bolt in. I used the converter from the f-body as well. The truck trans pan is deeper and holds a little more fluid, so I would suggest you swap those also.
Old May 3, 2011 | 03:06 PM
chubbz817's Avatar
Will do thanks to everybody who posted you guys really helped me out thanks
dantheman1540
Feb 24, 2016 09:56 PM
Chewy07
Nov 14, 2015 09:46 PM
NateBower002
Oct 27, 2015 01:04 PM
mitchellmade
Sep 27, 2015 08:25 PM
bluebommer07
Sep 20, 2015 08:42 PM
