f-body converter qestion, help asap
Old Jul 10, 2010 | 01:38 PM
Chevy Cowboy's Avatar
Piss Pumps for Sale
From: Moncton, New Brunswick, Canada, The True North Strong and Free!
Default f-body converter qestion, help asap
will a f-body torque converter work in our trucks? reason im asking is I bought a vigilante 3200 stall torque converter from a guy with a f-body anyways I can get the bolts to tigthen in all the way down to the flex plate, its like there about a 1/4 inch to long. do I need a truck converter? or just new shorter bolts?
Old Jul 10, 2010 | 05:56 PM
Circle-D's Avatar
Former Vendor
Same converter for any LS based 4L60 trans, car or truck. You just need to get some shorter bolts. Probably about 12 mm long. BTW - The thread is 10mm x 1.5 pitch. Also need to make sure converter pull back is about 1/8".
Chris
Old Jul 10, 2010 | 06:15 PM
terravast4's Avatar
Wont it stall differently because it is stalled for the weight of the f body and the truck is heavier?
Old Jul 10, 2010 | 10:42 PM
budhayes3's Avatar
PT's Slowest Truck
That is correct, there are a few factors that will affect the stall, including the weight of the vehicle and of course the power output of the engine. A heavier vehicle will make it stall higher I believe, and the more power the engine puts out, the higher it will stall. It's common for someone to see their stall speed increase anywhere from 200 to often over 400 RPM when swapping from a 5.3 to a 6.0
Old Jul 11, 2010 | 07:59 AM
Circle-D's Avatar
Former Vendor
Good point, probably should have mentioned that as well.
Chris
natejk
Nov 15, 2016 08:05 AM
gavin2005
Sep 13, 2015 09:04 PM
jtphelps289
Sep 11, 2015 06:37 PM
Hpinnovate
Sep 4, 2015 02:28 AM
