External by pass for tru cool
Old Mar 19, 2012 | 07:12 PM
40series's Avatar
Default External by pass for tru cool
Do the northern guys need the external by pass for the tru cool.
Old Mar 19, 2012 | 07:20 PM
2007chevy5.3l's Avatar
If it gets super cold up there id say yeah
Old Mar 21, 2012 | 10:08 AM
40series's Avatar
Default still on the fence about the by pass
do i need to get the Tru Cool with the by pass ???????????
GRANTED THEY HAVE A BUILT IN BY PASS
SO WHY DO THEY COME WITH A EXTERNAL ONE?
i live in MI
Old Mar 21, 2012 | 12:04 PM
neilownz's Avatar
If you want to run it with the stock cooler it makes it easier.
Old Mar 21, 2012 | 12:20 PM
40series's Avatar
Default what are you talking about
what do you mean the stock cooler is too small????
Old Mar 21, 2012 | 08:54 PM
neilownz's Avatar
Some don't use the stock cooler because if it breaks the trans will run out of fluid.
Old Mar 21, 2012 | 09:46 PM
40series's Avatar
Default I want a bigger cooler
I want a bigger cooler, stock is not a option , im trying to protect my investment
some don't use the stock cooler because if it breaks the trans will run out of fluid.
Old Mar 22, 2012 | 12:14 AM
cdub81's Avatar
40 series, not to be a dick but the 40k trans cooler is not this complicated. I'm no master mechanic but i did it in my garage in an hour and that was removing hayden 28k cooler. The external or internal thermal bypass is not rocket science. Just sell the truck and buy a Prius!
Old Mar 23, 2012 | 09:50 AM
Gordy M's Avatar
I have the 40 and run it through the radiator in place of the stock one. In several years of use I have not had an issue. In 90+ summer temps and pulling an enclosed trailer (7600 lbs) the temps rarely get above 170, usually about 150 deg.
Old Mar 23, 2012 | 03:00 PM
40series's Avatar
Default Good to know
Thats it im gon get a 40 , knowing a guy in mi has the good results
did you use the external by pass? The moderator said he thought i needed on here in mi.
Originally Posted by gordy m
i have the 40 and run it through the radiator in place of the stock one. In several years of use i have not had an issue. In 90+ summer temps and pulling an enclosed trailer (7600 lbs) the temps rarely get above 170, usually about 150 deg.
Avalanche2002
Nov 30, 2015 07:31 AM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
BlownHD
Oct 3, 2015 12:24 PM
Lthompson
Oct 2, 2015 12:45 AM
carid
Oct 1, 2015 09:22 AM
