Eaton Posi Rebuild?
Old Dec 9, 2005 | 02:55 AM
Grey Silver's Avatar
11 Second Club
Originally Posted by BigKID
Yes, all the gears inside the differential are refered to as the spider gears but they can be broken down into individual componets which are the side and pinion gears.
I am hoping I am not in the same boat as you but I guess we will see. Let me know how that truetrack works out for you as I was looking into those as a replacement if the Eaton breaks again. Did you get the one with two or three pinion gears?
Well I learned something here.Looks like I broke the side gear both times. 1st time it took a couple of teeth off. Last time it took a couple teeth and cracked the gear in half.
When I talked to the people at Tractech they said they sponsor johnny lightning and he's running a true track but it ain't in a 8.5 10 bolt. I think that's the real culprit here.
The unit I got has 3 pinion gears. I didn't know I had a choice. What's the take on that?
Old Dec 9, 2005 | 08:16 AM
TurboGibbs's Avatar
My trutrack has the 3 pinion gears. I read that they redesigned it due to breakage issues. I don't think they make the 2 pinion trutrack anymore.
Just to be **** but i've always refered to the side gears as side gears or axle gears and the smaller idler gears that are on the cross pin as spider gears.
Old Dec 11, 2005 | 10:18 AM
BigKID's Avatar
After getting it out, I broke 4 1/2 teeth off the driver side side gear which chewed up the two pinion gears a bit. The pass side gears looked great so at least I'll have one spare if it happens again. :\
As for the truetrack info, I didn't know they only made the 3 pinion now. That is good to know. As for JLP, I am assume he is running a 9"? I think our 8.6 is plenty strong as far as the gears, axles, housing is concerned where the differental is the weak point.
moregrip
Jul 26, 2016 11:21 AM
03sierraslt
14
Oct 9, 2015 05:53 AM
turbo6c3
Oct 5, 2015 06:11 PM
gmcyukon
Oct 5, 2015 06:20 AM
sTNT971
Sep 26, 2015 06:27 AM
