Eating Transmissions, Multiple 3-4 Clutch Failures
Old Mar 24, 2009 | 03:59 PM
retraC's Avatar
Exclamation Eating Transmissions, Multiple 3-4 Clutch Failures
Hi all,
I've got a 2001 Sierra 1500 4X4, originally with a 4.8, now a 6.0.
I've killed 4 transmissions. All 4 were used units, none with over 25000 miles. Two were left stock, one modified with a Vette & Sonnax Superhold servo, and the 4th with a full transgo HD-2 kit + Vette & Sonnax servos. All times the converter was swapped with different units and the cooler flushed. I monitor temps with a AeroTech scan gauge and have never seen a temperature over 160'F; nor have I ever read a code or had a MIL light. Failures occured with both a stock tune and two different tunes from Wait4Me, 3 failures were with the 4.8, this last one was behind the 6.0.
All failures occur while highway driving with a 'false neutral' whenever in D or 3; manual 2 and 1 work great.
I beat on the truck, I've always expected a sunshell or some other failure, but it's been my least abused point that fails.
I'm at a loss with this one; am I looking at a chassis electrical problem here? Thoughts? Things to track down?
I don't want to drop the money on a FLT if I'm just going to kill it again from some strange problem.
Thanks,
Paul
Old Mar 24, 2009 | 04:52 PM
built408's Avatar
lol, you keep burning up STOCK transmissions, so you replace it with another STOCK transmission???? The factory 3-4 clutch pack is weak, very weak. Get yourself a good BUILT transmission with a good 3-4 setup, lol I don't think you have a "chassis electrical problem".
Old Mar 24, 2009 | 05:00 PM
tarinitup's Avatar
9 Second Truck Club
Give Vince a call, your engine will go out before you break their level 5.
Old Mar 24, 2009 | 06:11 PM
retraC's Avatar
What a helpful post! I guess I'm nuts for hoping that a stock transmission might hold up behind a stock powertrain!
Old Mar 24, 2009 | 06:25 PM
KySilverado's Avatar
I had a slip in 2nd once that hurt my original transmission. I think it was electrical. Couple days later started getting misfires and found a plug wire laying against a header and had been arcing. Fixed that and its never done it again
Old Mar 24, 2009 | 06:50 PM
zeake's Avatar
Do 4l80 and be done with it. My FLT level 5 is holding up fine with a T76 turbo and awd launches. It started slipping a little and I had it serviced changed fluid and filter and bam back to like new. But when I kill it it will be a 4l80 from FLT.
Old Mar 24, 2009 | 06:58 PM
built408's Avatar
I wouldn't consider a 4.8 to a 6.0 swap stock, nor did you ever say it was stock. If you did a motor swap I would think it was modded.
Old Mar 24, 2009 | 07:06 PM
retraC's Avatar
I'm planning a FLT, at least a level 4. Knowing that I've toasted a mess of stock ones doesn't exactly make me comfortable putting it in if there's an underlying, non-trans, problem.
Keep ideas coming if you have any. A local shop wants me to check on the G110 ground condition.
Old Mar 24, 2009 | 07:16 PM
Wondering about temperature in your part of the country. Is there any chance you aren't getting fluid flow to the rear pack in the severe cold?
Old Mar 24, 2009 | 07:35 PM
retraC's Avatar
It's a possibility? Every failure has been in the winter. I have been using Chevron Dextron VI since it hit the market.
