Drum Brake Removal 2005 1/2 ton
Hello,
Trying to get the drums off a 2005 gmc 1/2 ton to paint drums. Manual said if it didn't come off to remove the plug behind the drum and turn the adjusting screw upward. I've turned and turned the screw upward and the brake shoes don't seem to be contracting at all. Drum still tight. I've give it couple good bangs but it's not coming loose.
If I can't get them off, do I need to rescrew the adjusting screw back to where it was? Or if I don't when I use the brakes will it just adjust?
I want to get the drums off, but have never had this problem. Truck has 40K miles and drums have never been off.
Thanks in advance,
Corey
Thanks in advance,
Corey
hey man welcome to the forum! the slack adjuster shouldnt need to be adjusted in too far unless the drums are realy worn on the inside, there shouldnt be enough of a lip in the drum for the shoes to hang up on. i say get a bigger hammer, and beat on em from all angles. i have seen some so bound up from tight clearances and rust in between that only a bigger hammer would cure. me and a buddy beat on a set for about half an hour with a sledge before we saw movement.
Grab the drum and wiggle it side to side while starting to pull it off, clockwise and counter clockwise, this helps sometimes too. You tried going upward with the star adjuster and nothing happened, did you try going downward at all? It has been a while, I forget which direction backs the shoes off of the drum......
Corvette454l88
Sep 1, 2016 01:24 AM
FlowmasterMufflers
Aug 14, 2015 12:47 PM
FlowmasterMufflers
Jul 17, 2015 03:26 PM
