driveshaft help!
Old Sep 22, 2008 | 07:53 PM
homer713's Avatar
Default driveshaft help!
i have an 05 crew cab chevrolet....i lowered it 3/5 and now i have trouble with d drive shaft every time i hit aruond 60 mph it hits on the chasis bar that holds the gas tank and i dont know what to do any suggestions please help
Old Sep 22, 2008 | 09:17 PM
built408's Avatar
why would it hit only when you go 60mph? Are you sure it's not hitting when you hit a bump and the suspension loads? What lowering kit did you use? Does it say anything about this in the directions?
Old Sep 22, 2008 | 09:30 PM
homer713's Avatar
it doesit when i floor it around 60 and i used the djmdrop kit
Old Sep 23, 2008 | 09:59 AM
Last Call's Avatar
TOTM: January 2007
Are you it is not from the driveline angle?
Old Sep 23, 2008 | 11:29 AM
built408's Avatar
something in the rear suspension must be moving under a load, causing the driveshaft angle to change.
Old Sep 23, 2008 | 01:20 PM
skeet's Avatar
if its a single drive shaft its posible you maybe getting shaft deflection underload.. most likely vibrating.. angle probably needs fixing
Old Sep 23, 2008 | 06:03 PM
95 bright teal's Avatar
I would shim it first, if it isnt done already, thats a really low 3/5
ls1curt
Jan 5, 2016 11:33 AM
turbo6c3
Oct 5, 2015 06:11 PM
jscherbs
Sep 30, 2015 07:54 AM
97_ek
Sep 23, 2015 09:16 PM
ice17
Sep 22, 2015 05:18 PM
