drive shaft is in heaven now
Old Jul 20, 2008 | 01:54 AM
artypyro's Avatar
12 Second Club
Default drive shaft is in heaven now
was coming home tonight, pullin my trailer. noticed a vibration, thought maybe it was just the rough *** roads. then it got worse, before i could get pulled over to check my tires, BANG, seen my driveshaft fly out from under the driver's side of the truck. I don't think my u-joints were bad cause i just checked em bout a week ago. the front yoke is still in the transfer case but doesn't slide back and forth now. I imagine it might be bent, seeing how as the adapter between the tranny and transfer case is now broken
so heres my question, what should i do now? should i find a driveshaft out of a junk yard or get one built. any idea what this might cost me? stock driveshaft was aluminum by the way. anyone know where to find the adapter that i broke, tranny is 4l60e
thanks in advance
Old Jul 20, 2008 | 02:11 AM
GMCtrk's Avatar
that is really weird that you have an aluminum driveshaft.
I also have a 2000 sierra ecsb, but with 2 piece steel striveshaft. Mine is 2wd though, maybe only the 4wd's got the aluminum.
From what I've read, a pretty good option is to get another stock driveshaft and have it balanced at a shop.
Old Jul 20, 2008 | 08:55 AM
venomhp's Avatar
Ive got aluminum as well, I had mine lengthened when it was lifted, but I would say go to the junk yard and pick one up, but if you do have one made its anywhere between 350-450 depending on where you go and the quality of it. Id check your output bearing on your transfer case. I threw one out of nowhere on an older truck I had, and after the second time I threw it I started investigating because I knew it wasnt the U-joints.
Old Jul 20, 2008 | 01:48 PM
artypyro's Avatar
12 Second Club
ill probly try the junkyards tomorrow see what i come up with,then call the driveshaft shop and see what they can do.
thats good to know about the bearing, ill make sure and check that
thanks
GXPJAY
Feb 13, 2022 08:15 AM
Blue03sss
Mar 7, 2019 05:06 PM
Zacholcomb
Sep 3, 2015 06:14 PM
Ketis
Jul 23, 2015 12:37 PM
