Drag tires for 20's?
Old Dec 1, 2004 | 04:20 PM
  #81
Todd@AZPowerAndSound's Avatar
Originally Posted by unklej
Todd, did the tires on both rims have the same OD?
02denali... maybe I do...
sure did
Old Dec 1, 2004 | 05:13 PM
  #82
unklej's Avatar
well there you go, 8 hp on the dyno. So that would be 16 hp at the track since you have to accelerate the front wheels too.
Jeff
Old Dec 1, 2004 | 05:30 PM
  #83
I think the fronts add some (mostly in rolling resistance), but I wouldnt say its an equal equation both front and rear
Old Dec 1, 2004 | 06:11 PM
  #84
unklej's Avatar
Well, I could be wrong, but the moment of inertia doesn't change based on the wheel's location. You still have to spin that wheel up to the same speed. It should take the same amount of energy...
---EDIT---
OK, I thought about the 8 hp you made on the dyno and what power increase you would see from switching the front tires. The hp gained in the rear will be the same gained in the front by switching the rims and tires. But, I'm not sure you would see the same gain on the street due to rates of acceleration. If you can accelerate on the street at the same rate as on the dyno, you will see 8hp front and rear for a total of 16. But, if you can't accelerate at the same rate you will see less of a hp gain front a rear. I think that makes sense
Old Dec 1, 2004 | 10:43 PM
  #85
creederado's Avatar
Old Dec 1, 2004 | 10:56 PM
  #86
My trucks gonna do whatever in the 1/4 mile with the VHO 20's and some fatter beefer tires!!!!!!!!!!
Old Dec 2, 2004 | 07:13 AM
  #87
Scream's Avatar
MOOBIES Moderator
Originally Posted by creederado
Are your rear tires 9.5's or 10's? What kind of backspacing are you running?
Old Dec 2, 2004 | 11:48 AM
  #88
12sec.5.3's Avatar
I'd like to know this also. It's probably 9.5's all around.
Old Dec 2, 2004 | 12:20 PM
  #89
greentahoe's Avatar
---EDIT---
Damn dude, you are making my head hurt. For those of use with biochem and business degrees could you put this into laymens terms?? Is the the hp gain due to the smaller overall diameter of the 18 as opposed to the 22 or the weight difference or a combination of both???
Old Dec 2, 2004 | 12:27 PM
  #90
is pretty much what I have to say.
Bottom line is:
Wheel & Tire assemblies that have a majority of their weight pushed out farther from the center...will have an effect on power, accel, and decel. There are times where a 16" assembly could be more hurtful based on wheel choice, but generally speaking the larger diameter 20-22-23-24" stuff will really start taking its toll. Even if its a relatively light 22" package like mine 75lbs total per corner.
Bigger wider tires up front will increase rolling resistance 1st...which will hurt accel.
You want the lightest possible assembly you can get with the weight as centered as possible to get the best results for drag applications.
I dont think anyone should dwell to far in to this. If you wanna run 10s...run 15" or 16" on slicks. If you wanna go 11s-13's and look good, buy some light 20-22s and buy a bit more hp while you're at it
