Doesnt always downshift to first?
Old Aug 6, 2007 | 06:53 PM
Vicious-Peanut's Avatar
Default Doesnt always downshift to first?
Hello everyone.
I know this inst an LS1 truck, but it uses the same type of transmission and you guys are very knowledgeable so I figured I would give it a shot.
My 2001 S10 2WD 4.3 4L60E is having a problem where if I come to a sudden stop and don't stay stopped for at least a second or two it will start off in second when I go back to accelerate and then jump down into first. Also a few days ago it did it for the first time where I stopped for about 30 seconds at a light and went to go and it still wasn't in first, it started in second and jumped into first. It also jumps alot when I put it in reverse or drive, even with the brakes pressed all the way, which leads me to believe it is an electronic problem. It was flushed about 5k miles ago and some people I've talked to blame this on the flush and claim the transmission is dying. Could it be, or might it just be a bad sensor or something? Oh, by the way the fluid is nice clean, red and doesn't smell burnt.
Thanks for any help.
Old Aug 6, 2007 | 09:37 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Originally Posted by performabuilt
The first step to solving your problem will be to see the data stream and see what the PCM is commanding if the pm is commanding first and its not happening then you have a internal problem possible VB problem the flush could have pushed something into the VB
Good advice.
Old Aug 7, 2007 | 10:56 PM
64CAMINO's Avatar
gm had a tsb about this a few years back. they update the trans software to fix it.
Old Aug 7, 2007 | 11:36 PM
FLT's Avatar
FLT
FormerVendor
A broken 1-2 accumulator piston can cause a similar condition as well. Might be something to have check out as well as having the computer check for the actual command of the gear. Pretty cheap fix but I do recommend getting it looked at asap or you will be in need of a new transmission due to a band failure if in fact the piston is broken. Vince
Oobray
Jun 13, 2022 03:38 AM
drummer0415
11
Oct 24, 2015 08:16 PM
01silvy
Sep 26, 2015 10:20 PM
meadows
13
Aug 25, 2015 08:29 PM
