Do i need a tranny cooler??
Old 10-30-2009, 10:12 AM
Escalanche07's Avatar
thanks
how do i put my modifications in my replies ?
Old 10-30-2009, 10:18 AM
how do i get a sig to put all my mods ??? new here
Old 10-30-2009, 10:39 AM
fastnblu's Avatar
Originally Posted by viciousknid
Tru cool MAX 40k GVW on ebay for 120+- is the largest out right now. That should keep your temps around 150+-.
The cooler the better. Without a Cooler i was running 200-209 degrees. With one i'm usually around 140.
Do u need 1? Yes, I don't think a tranny can be too cool. I agree w/. others. Get largest u can afford/ find/ fit & also tranny temp gauge. If stock I think they're a great idea, especially if towing or have a stall.
jerry"n.l.c", IDK if it slows u down when its hot, it certainly doesn't add to tranny longevity.
A cooler is cheap insurance.
How much is a stall? How much is a new tranny?
Don't chance it, give yourself piece of mind. Heat is #1 killer of trannies.
Old 10-30-2009, 10:59 AM
TX Tahoe Z71's Avatar
I removed my stock cooler and put the 40k in its place using the stock hard lines coupled to the rubber hoses provided in the kit. Keep the trans fluid run through the radiator though, it helps warm the tranny up when it's cold outside.
Old 11-03-2009, 05:48 PM
Wonderer876's Avatar
Originally Posted by jerry"n.l.c"
and yea im getting the trans temp gauge also wat should the temp be around?
Do you have a DIC in your gmc? My NNBS silverado does. I fit does scroll thru your stiff and you will find your trans temp gauge
Old 11-03-2009, 06:29 PM
Luke03's Avatar
I would recommend the tru-cool 40K cooler as well. Like TxSilverado said i would just run this cooler by itself... its pretty big.
Here is mine
Old 11-03-2009, 06:59 PM
Formerly darynC-10/23/10
Daryn's Avatar
i have a 24000 i think. my trans temps usually get about 175-180 . but takes forever for it to get there. usually 30 min of driving , also the size of your converter IE 9.5'' wil run hotter than a larger 10.5 converter because of the fluid its tryin to push
Old 11-03-2009, 07:07 PM
nonnieselman's Avatar
my temps stay really low, around 120 cruising.. ive seen them get up to 174 after brake stalling it to 4400 a few times and several WOT runs.
Old 11-03-2009, 11:19 PM
Daryn's Avatar
my temps use to be around 150-160 before the new rebuild. i dunno what thats all about. maybe goin from a 70 pump to a 65?
Quick Reply: Do i need a tranny cooler??
