DJM 4/6 lowering kit
Old Jul 14, 2013 | 09:03 PM
hodge9386's Avatar
12 Second Club
Default DJM 4/6 lowering kit
anybody ever use this kit from djm? how did it ride? will come back into alignment?
http://www.summitracing.com/parts/dj...silverado-1500
seems like a good price, i know i will still need shocks but is there anything else you recommend?
also thought about getting these to help with the alignment
4951 Belltech - Front Alignment Kit At StylinTrucks.com
also which of these shock do i use for a 4/6 drop
http://www.stylintrucks.com/parts/be...ELSH88451.aspx
Old Jul 15, 2013 | 12:48 AM
PuroDesmadreSs's Avatar
Ived used that kit with those shocks on a couple of trucks and rode damn good. Always got close to a perfect alignment. And never needed the alignment kit
Old Jul 15, 2013 | 05:54 AM
hodge9386's Avatar
12 Second Club
Awesome thanks, which length shock did you use?
Old Jul 15, 2013 | 10:36 AM
spent21's Avatar
i researched my 2/4 drop to death, and found that folks were complaining of bumpsteer with the LCAs. I have a set of Belltech spindles on the shelf that I'll be installing this weekend.
Old Jul 15, 2013 | 04:56 PM
I can't recall the length but I think it was the shorter ones
Old Jul 15, 2013 | 05:44 PM
hodge9386's Avatar
12 Second Club
I really to do a 2" drop spindle an a 2" lower control arm but is expensive. I think it would be the best ride. What about a 2" spindle an a 2" drop coil? Would that be better?
Old Jul 16, 2013 | 07:33 AM
spent21's Avatar
i think that is what most everybody is doing.
Old Jul 24, 2013 | 05:29 PM
TheSuspensionSource's Avatar
FormerVendor
You are correct about the bumpsteer being an issue. I recommend using the spring and spindle method over arms. With a 4" drop I would also run Street Performance shocks by Belltech.
Old Jul 25, 2013 | 08:15 AM
spent21's Avatar
Kris,
Do you recommend drop shocks for a 2/4? and do you recommend using shock extenders on the rear?
Thanks
Old Jul 25, 2013 | 09:56 AM
FormerVendor
Originally Posted by spent21
Kris,
Thanks
I recommend using lowering shocks on any lowering kit. The rebound is much greater than OEM. This helps improve the ride quality. OEM shocks were designed to work with the OEM spring rate and height.
2/4 I would recommend Nitro Drop 2s for 88-98 and 99-06 trucks. 07+ Street Performance in rear.
Shock extenders are not required with such a mild drop.
GXPJAY
Feb 13, 2022 08:15 AM
Verz
Aug 21, 2015 06:40 PM
DONTH8
Jul 26, 2015 06:59 PM
khoult
Jul 15, 2015 03:54 PM
