Different Kind of Carnage (at least for me)
Old Aug 13, 2008 | 02:53 PM
Originally Posted by 1BADC10
Time = .250 (if memory serves)
Pressure = stock & lower (depends on gear)
Pressure Control Solenoid (PCS) = physically not modified
Lower than stock pressure setting allowed for "slipping" effect during downshift transition... The PCS tried to raise fluid pressure to satisfy setpoint (detected by PSA) before PCM commands downshift. Pressure setpoint was eventually satisfied (coincidentally whilst I started to let off the "go" pedal), and PCM commanded the gear change. Unfortunately, higher pressure buildup was already in the works, PCM got the go-ahead for downshift, but me letting out surpassed that requirement & allowed 3-4 fluid feed (de-energized B solenoid) for harder 3rd/4th apply (with the 2-4 band not being applied to the reverse input drum yet). I strongly suspected the apply force (surge of pressure) ultimately compressing the apply plate, steels and clutches against the retaining ring is what killed the "tangs" on the drum.
As for me thinking to adjust pressure settings to soften shifts, that probably wasn't the best route to go (obviously, right?). Vac mod would eliminate "hunting" (IMO), and should give me a faster pressure response. Who's to say the solenoid operates as it should at all times? I have some time to think about this. Remember, I'm no pro, so I gotta study this longer than those who've done this for over a decade.
BTW, trans shifted PERFECT at WOT. The problem was always at part throttle and downshift transitions.
I SEE U STILL HAVING TROUBLE WITH THE TRANNY U SHOULD OF BOUGHT A BUILD UNIT FROM CHUCK AND WOULD HAVE BEEN DONE WITH IT ALREADY HOPE TO MEET U DEC. 13 AT HOUSTON AND UR TRUCK CAN MAKE A COUPLE OF PASSES
Old Aug 13, 2008 | 08:43 PM
95ImpSS's Avatar
formerly 1BADC10 (12/14/2011)
Gotta pay to play. Unfortunately, I don't have deep pockets, and need to use my truck for what it is made for from time to time. Had I met half of the performance nuts before I got married then I'd have probably postponed married life until I was finished with my pre-mid life crisis. why don't ya start a charity fund to giveaway a built trans on the quarterly basis for one year, and help those strapped for cash!
Old Aug 13, 2008 | 10:12 PM
chevyguy7802's Avatar
Damn that sucks bro!
Old Aug 14, 2008 | 09:51 PM
SBTork's Avatar
wow, sucks about your luck lately, but, maybe a built trans could be an early christmas present from your wife
Old Aug 15, 2008 | 07:48 AM
built408's Avatar
Ive measured line pressure with and without vac mods. The pressure response with the vacuum mod is waaaaay faster the with the pc sol. The PC sol will delay when downshifted and fluctuate at part throttle. I recommend the vac mod for all performance trannies I build. I run one in my truck and its held up about 15,000 miles no prob. Line pressure at wot is about 235.
SloSVO
Nov 22, 2020 07:34 PM
Alco
Jul 20, 2016 04:53 PM
Vortec350ss
Jan 12, 2016 10:36 PM
JordanH
Nov 6, 2015 07:42 PM
Slammed silverado
Sep 28, 2015 06:14 PM
