Difference between Eaton LSD and Detriot Tru-trac
Old 06-26-2006, 06:54 AM
tdrumm's Avatar
Default Difference between Eaton LSD and Detriot Tru-trac
What are the functional differences between the Eaton LSD and the Detriot Tru-trac? How would it affect daily driving?
Old 06-26-2006, 07:35 AM
2nd fastest 5.3 ECSB
trever1t's Avatar
The TruTrac is mechanical, no clutches to wear. Both great products.
Old 06-26-2006, 07:45 AM
nonnieselman's Avatar
http://www.detroitlocker.com/DT.htm
on the picture of the Detroit TT you can see the set of gears inside the differential.
http://www.traction.eaton.com/prod3.htm
kindof hard to see but the Eaton LSD has a set of clutch packs on each side with springs press against them from the center.
Im sure for DD you will not know that there is anything in the rear. They both behave pretty much like a Open diff until you call on them.
hope that answers your question?
Old 06-26-2006, 08:25 AM
tdrumm's Avatar
There would be no "clunking" around turns from the Tru-trac?
Old 06-26-2006, 08:52 AM
Colby 04's Avatar
I disagree a little, my eaton is tight. With the windows down cruising through my neighborhood, I can hear my inside tire trying to grab going through a turn. I'm happy with my Eaton
Old 06-26-2006, 08:54 AM
Colby 04's Avatar
The Eaton will not "clunk"...the tru-track, I believe, will ratchet around turns....not exactly a "clunk", but more of a clicking noise.
Old 06-26-2006, 10:40 AM
02sierraz71_5.3's Avatar
I should have bought the trutrac, I kick myself daily I called eaton(who now owns detroit) about the trutrac and they have several in 1000+hp drag cars and they hold up great. I came across a great deal on an Auburn brand new and have regreted it ever since I put the bitch in.
Old 06-26-2006, 11:36 AM
jus1975's Avatar
What is wrong with the Auburn?
Old 06-26-2006, 02:40 PM
Its a POS I dont want to take up this guys thread getting into it, if you want more info PM me.
Old 06-26-2006, 03:00 PM
i have the factory G80 right now.. but im ordering a Eaton LSD this week..
So i just got that info off a website..
but ive heard of a few broken TruTracs... ill try to find more info on the specifics though..
Quick Reply: Difference between Eaton LSD and Detriot Tru-trac
