did this load cause this oil leak?
#21
#25
#26
Basically, screw the thing on by hand so that it will seal, won't leak, and won't fall off. There's no need to gorilla the oil filter on...case and point:
I'm sitting on my bed right now, 12 hours after going through surgery for a hernia that I suffered after attempting to remove an oil filter housing (cartridge style filter), that one of my coworkers installed with an impact gun. The torque spec for that housing is 3 in/lb
When I change the oil on my truck, I can usually get the filter back off by hand at the next oil change, without using a wrench...it doesn't need to be that tight
#27
You don't need a wrench to put an oil filter on, unless it's the proper cup type with a torque wrench, which is ridiculous. "Hand tight and then a 1/4 turn" is like saying "as tight as I can make it, then a little more". Depending on the manufacturer, filter manufacturer, etc, there are actual torque specs for the oil filter, but a basic rule of thumb is to get the o-ring to touch the block completely, then go an additional 1/4 to 3/4 turns, again, depending on the vehicle manufacturer, filter manufacturer, etc.
who the f*** would install an oil filter with an impact?
#28
My problem is my hands are to fat to grab the effin filter on out truck and put some good pressure on it, and the cup i have doesnt fit worth a flip cuz of the pan clearance. So i use my strap wrench and go 1/2 turn.
Im with budhayes, oil on exhaust is smoke.
#29
Other techs have told me that they've seen him installing the filters with a 24" breaker bar
I'll say it again...3 frickin in/lb
In your case, I'd get the proper cup style tool that fits over the end of the filter, and will cause minimal damage, cosmetic if anything. I believe that a few companies make the cups...if I were to guess, I'd say OTC, Lyle, KD to name a few. There are probably stamped steel versions available, vs the aluminum cast versions. For most guys, who use the tool on their own vehicle only and don't over tighten the filter, the cast aluminum cup tool should be sufficient. But if you plan to use the tool repeatedly, and possibly on vehicles where a gorilla installed the filter before you, you're going to want the stamped steel cup tool, as the cast aluminum one will eventually break...I've broken numerous cast aluminum Toyota oil filter cup tools, and most recently, the day I got the hernia, blew apart my brand new Lexus oil filter housing cup tool. Luckily I didn't pay for it, a local tool manufacturer dropped it off to me to test out and report back to him...I still have the blasted thing in pieces in my tool box (hope the box is still there when I get back in a few weeks
)*EDIT* Using the strap style wrench to install the filter can dent or crush the filter body, and may even possibly affect the operation of the filter itself
#30
Filter wrenches damage filters. They also overtorque them, which makes removing the filter later, a major PITA. Or in Billy's case, a major PIT-*******...
General rule of thumb, if you can't get the filter tight enough by hand to not leak, maybe your man-card needs pulled...
