Dexron VI into a used 4L60E
I bought a used 4L60E with 80k miles on it from a friend and have drained all of the old fluid from it. I intend to install it on my truck which I am putting back to stock. It will be my daily driver for a short period of time.
Would it be okay to refill it with Dexron VI fluid? I have a ton of this fluid sitting on the shelf and would like to put it to good use.
I believe GM now recommends using Dexron VI in all new and old transmissions to supersede Dexron III.
Thoughts?
Thoughts?
He asked if the Dex6 he already had laying around was ok to use in a used transmission. Not what he should go out and purchase.Dexron 6 is Gm's replacement fluid for Dexron III and will work just fine. Especially when he already has it.
80k on it shouldn't be a problem. This issue is more in changing the fluid at all than it is changing to Dexron VI. Old ATF loses its detergent properties over time. The detergents keep things clean by preventing deposits. After many heat cycles, or miles, or age, the fluid gets to a point where suspended particulates in it begin to deposit themselves into all the corners and cavities inside the valve body. That generally doesn't cause any problems because those chunks of deposit build-up stay put with the old fluid. However, when fresh ATF is introduced with full-strength detergents, it can cause those deposits to break loose and create fluid blockages. With only 80k on it this is not likely to be a problem, just be aware that this is always a possibility when fully replacing the ATF in any automatic.
Well I put the transmission in this weekend and topped it off with 11.5 quarts of NAPA Dexron VI and it seems to be working fine. The old fluid that came out of it was exceptionally clean, and there was very little "sludge" in the bottom of the pan.
thank
_Zblee
Generally speaking I've changed Dexron-III at 50k and VI around 75k. These are all transmissions with shift kits and performance clutch materials, and deep pans, but driven hard. I'd have to say a stock smooth-shifting trans will expire the fluid in fewer miles than what I am getting out of them realistically.
Get more opinions too; there is a lot of experience out there on this subject.
