Denali AWD lower ball joint replacement? how the heck...?
Old Aug 3, 2012 | 10:20 PM
bighoss77's Avatar
Default Denali AWD lower ball joint replacement? how the heck...?
okay, done plenty of ball joints, never seen one like this. 2004 Denali AWD. we are trying to replace the ball joints. the lowers are tricky, they have the big fat lip on the bottom, which means they are to be pressed downward through the lower a-arm and out the bottom. problem is, they also have a lip on top that hangs over the hole with 4 flat spots where a machine spread them out. are we supposed to cut the whole dang top of the ball joint off to be able to press it out? theres no way it will press out with the way it is... tried doing a google search and a search on here and didnt find much help. anybody have any tips?
Old Aug 3, 2012 | 11:03 PM
Silverado53's Avatar
Use a sharp chisel and knock off the "ears" as close as you can and it should press through. This is what worked for me when I did my Tahoe's lower ball joints.
Old Aug 4, 2012 | 01:54 AM
bighoss77's Avatar
yeah we tried that on the passenger size, even used and impact on the ball joint press tool and it would not budge. i guess we'll try harder tomarrow!
shupe
Aug 5, 2015 06:45 PM
Kaldar
Jul 27, 2015 06:42 PM
Ketis
Jul 23, 2015 12:37 PM
Denali man
Jul 19, 2015 03:52 PM
cwylie
Jul 7, 2015 11:42 AM
