Deep ANUS?
Old 02-03-2015, 07:08 PM
  #51
Resident Retard
BlackGMC's Avatar
Naw just a jab in the ribs buddy.
Old 02-03-2015, 07:16 PM
  #52
03sierraslt's Avatar
When I first seen the title I thought somehow I missed this thread and it was a thread dig.
Old 02-03-2015, 07:42 PM
  #53
Fastest D1 Procharged Truck
02_Orange_D1SC's Avatar
this thread is full of LOL
Old 02-03-2015, 07:47 PM
  #54
shupe's Avatar
Subscribed. Let the discussion continue.
Old 02-04-2015, 12:16 AM
  #55
Jordan927's Avatar
Deep pans...coolers...Bla bla bla....
Deep Anus...you need one of these!!
Old 02-04-2015, 08:21 AM
  #56
11 sec. Truck Mod
TIM Z's Avatar
Originally Posted by thunder550
I am not a trans expert by any means, but FWIW I was told by THE Allison guru not to waste my money on a deep pan when I had my trans built.
That's a different animal though Brutha , ask Mike about 4L80E's he's built for the mafioso on the left coast
And yeah Mike and Eric Merchant , Big Dipper , Guy Tripp have all agreed a big fancy mag hytec pan on an Allison is a waste , that why I ran the factory deep Allison pan
Old 02-04-2015, 10:49 AM
  #57
TXsilverado's Avatar
Originally Posted by custm2500
People are missing the point. A large cooler with a fan will never let trans temps get past 150 set it up.
lets put my converter in a heavy Silverado and put your theory to the test...I've cooked 60e transmissions with smaller converters and a 40k cooler.
I have a few reasons for running a deep pan. 1) my trans brake requires the use of a deep pan 2) I run a 6,000 converter and my truck doesn't have the room for a 40,000 trans cooler 3) expensive transmission that I want to protect. I don't even have a trans temp gauge on my truck.
Old 02-04-2015, 11:26 AM
  #58
this guy makes sense...
Originally Posted by Jordan927
Thermodynamics. The Law of thermal conduction. Its all about heat transfer.
Oil gets hot because of this. More oil to pump through the system means each oil molecule is in contact with each piece of metal for less time, This also means each oil molecule is in the pan for longer and therefore transfers more heat to the metal pan which is cooled by ambient air temp.
There is no insulation effect with hot oil on top of cool oil...the turbulence in the pan will mix them...they will equal out in temp quite quickly so the hotter oil will get cooler and the cooler oil will get hotter...the more cool oil there is the more heat can dissipate into it without much increase.
This also means that there is more oil to transfer the heat of the trans into, thereby increasing the oil's capacity to cool.
Finned pans mean more surface area in contact with the air and therefore more heat transfer to the air.
The other benefit of finned pans and large capacity pans are that they are usually constructed of Aluminum alloy, which has a greater ability to conduct heat than steel does. Hence the reason coolers are Aluminum construction, they used to use copper when Aluminum was expensive. Copper is even better at transferring heat....copper bottom pots and pans for example, and even if they don't have copper bottoms...they usually sandwich a piece of aluminum into the bottom of stainless pans.
Do you need a deep pan...absolutely not. You don't even need an external oil cooler....as long as your not cooking the trans during your daily dealings. Lost of transmissions are cooled by a section in the cold side of the rad..and that had been done for years.
I don't think there is really a wrong answer to how to cool....but saying that a deep pan does nothing is most definitely wrong.
For the record..deep pans are 50-200 bucks...with the standard being 150 (200 for a 4L80). I have no idea where this $300 number got pulled from as the standard... maybe a TCI or Mag Hy-Tec...but those look cool too...so that has a lot to do with it.
That cool looking Derale pan with the pipes through it, previously posted, is only 150 bucks...but its made of steel. Also, it says on its site that this pan can cool fluid by 20-50*, and adds 4.5 quarts of fluid. That's as much as a standard fluid cooler say 7"x15" with 6 cooling rows, they claim 20-30* cooling.
Fan coolers claim up to 70-95* on average. A cheap one is 150 Bucks and go to about 500 bucks, depending on size and name brand
You can add a pan for 150, and get up to 50* more cooling, or change out your old cooler and increase cooling by up to 65*...(95*- 30*) for the same 150 bucks.
Old 02-04-2015, 11:31 AM
  #59
Ya, lots of valid points. It comes down to the setup, the goals and personal preference IMO. I dont like the deeper pans that do not have a filter extension tube.
Old 02-07-2015, 10:23 AM
  #60
formerly slow03 (11-04-2011)
slow2008's Avatar
How did I miss another Custom thread?
03chevytruck
11-07-2016 04:43 PM
superchomper2003
08-26-2015 09:39 AM
06 4.8
08-16-2015 06:16 PM
Quick Reply: Deep ANUS?
