Death wobble, shake from hell
I also recommend the tie-rods. I have had the DW before and the tie-rods were shot. Its not fun at 70 mph, have to have a crowbar handy to get the seat out of your a$$!
Tie-rods, pitman arm, that should take care of it. Good Luck
Google frame beaming. You have the same issue I am having. Depending on the year model of the truck You can replace the rear cab mounts. I am going to try a few other things before paying for those mounts.
its not the cab mounts
but thanks man
When mine was lowered it had some pretty bad bump steer if you hit something just right.. Mine had alittle camber but the tow was set in spec. I was a lot lower in the front then you are though. I would just check over everything there's gotta be a loose link somewhere
i will check it as soon as i get back home. its a few inches lower than the pic i have up.
but it wolnt be lowered for long i ordered a t-bar key leveling kit with the 3 in blocks and a 1.5in body lift
i really hope its something easy
