Crush Sleeve issue
Old Mar 1, 2011 | 06:45 AM
Chavette's Avatar
Originally Posted by blown02408
How do you get a 4' long wrench under a truck on jackstands and turn it....lol!
Dig a big hole.
Old Mar 1, 2011 | 07:34 AM
TurboGibbs's Avatar
Originally Posted by 6789olds
the crush sleeve lets you tightin your pinion nut with out pre loading the pinion bearing too much . it also holds pre load on them . no you can not use the old one the preload is measured in roatating friction . not torque on the nut . once the crush sleeve starts to crush you need to measure how much "inch pounds" it takes to get the yoke to rotate . i beleive its like 20 inch pounds . so with no load on the rear end when you spin the yoke it should have slight drag 20 inch pounds this is without the carerer in the housing . kinda like doing a wheel bearing. lube up the crush sleeve put a 48 inch pipe wrench on the yoke to hold it then i use a 3/4 inch drive breaker and a 4 foot jack handle cheater .
Yes you can. I've been doing it for years and have re-used crush sleeves over a dozen times with no failures. You have to know what you are doing. If it is your first rear end build, using a new crush sleeve is recommended.
Old Mar 1, 2011 | 07:38 AM
6789olds's Avatar
lol yeah its a pain you can only get like a 1/8th of a turn at a time . once it starts to crush you can take off the cheater and tightin a lilttle bit then rotate , then tightin and keep rotateing till you get the pre load you need . i had the cheater going out the driver side then you can push down "stand on it lol." you wil feel it crush and start to get easyer .
Old Mar 1, 2011 | 08:05 AM
KLUG'S SS's Avatar
FormerVendor
I've done the same 4 or 5 times with no problem at all. Like TurboGibbs stated though for the guys that arent quite as experienced with it I would definately recommend just using a new crush sleeve.
Idryfly5
Sep 2, 2022 08:55 PM
murderedSS
27
Oct 12, 2015 11:13 AM
TAPyvehc93
Sep 14, 2015 01:22 PM
dselby25
Sep 11, 2015 05:03 AM
Boyes50
Sep 8, 2015 12:06 PM
