Converter Questions...
Old Dec 18, 2007 | 10:43 AM
spinz71's Avatar
Default Converter Questions...
I did a search but couldn't find what I was looking for so here goes....
1) When in Drive and at a complete stop, is the TC locked or unlocked?
2) On a Vac. Mod 4L60E, what controls the TC lock up?
TIA and happy holidays!
Old Dec 18, 2007 | 11:26 AM
1989k1500's Avatar
The tc is unlocked when your stopped.
Old Dec 18, 2007 | 12:36 PM
95ImpSS's Avatar
formerly 1BADC10 (12/14/2011)
1. When stopped (or pushing the brake pedal), the TC is unlocked.
2. TC lockup is controlled by the TCC lockup solenoid. The 46-MOD (for the 4L60E) replaces the pressure control solenoid (different from the lockup solenoid).
Old Dec 18, 2007 | 02:49 PM
spinz71's Avatar
Thanks guys.....some more questions then. Supposing the TC were locked when stopped, what would the symptoms be or how would you know?
Old Dec 18, 2007 | 02:58 PM
joshua022's Avatar
It would be overheating.
Old Dec 18, 2007 | 03:01 PM
Spoolin's Avatar
GFYS and STFU
Your car would stall and die. Same as having a stick in gear at a stop light.
Old Dec 19, 2007 | 09:28 AM
spinz71's Avatar
Thanks again for the replies. More questions in my quest for knowledge...
Does the TPS play a part in shifting? If so, what?
Does the VSS play a part in shifting? If so, what?
Old Dec 20, 2007 | 08:57 AM
spinz71's Avatar
Thanks Spoolin.....what would happen if the truck were stopped and in second gear?
Old Dec 20, 2007 | 10:41 AM
Bill Reid's Avatar
You can pick up an ATSG manual (with supplement) on ebay for dirt cheap. In that manual it goes through just about every conceivable scenario on troubleshooting. It also shows you how to do a basic rebuild... including recommended specialized tools.
Bill
Old Dec 20, 2007 | 11:21 AM
95ImpSS's Avatar
1. TPS output tells PCM helps PCM determine what gear to engage based on forward speed and throttle position.
2. VSS provides the actual speed to help determine which gear to shift in.
Take Bill's advice on acquiring an ATSG manual, or PM me. Maybe we could work something out. Not that anyone doesn't want to answer questions, but the manual is actually a great learning tool for basic transmission operations & troubleshooting. You can get e-copies of those online for ~$35+ each.
