Clutch pedal stiffness
Old Mar 6, 2014 | 11:55 PM
MaukaRunner's Avatar
Default Clutch pedal stiffness
Hey, looking at buying a '02 Silverado RCSS with a 5 speed manual. When I test drove it, the clutch was real stiff. Felt stiffer than my street strip clutch in my old Z-28. The clutch released fine and there was no problem shifting. Is this common for the manual trans trucks?
Old Mar 7, 2014 | 12:15 PM
SYRacing's Avatar
Stiffness usually isn't, depends if PO installed a heavier duty pressure plate.
I know the pedal assemblies are prone to failure but they usually pop and squeak before they break
Old Mar 7, 2014 | 01:05 PM
Thanks for the reply. I hope that's the case. I'll take a look once I'm in possession of the truck.
Old Mar 8, 2014 | 10:42 AM
topfueljim's Avatar
It's a hydraulic clutch, of course, with the slave cylinder and release bearing all one piece. If your master cylinder, line, and slave are all OK, it shouldn't be stiff at all. There is something wrong.
Old Mar 11, 2014 | 04:46 PM
Thanks. I got the truck on Friday and looked at he fluid. Looks like dirty motor oil. I'll try to flush the fluid.
Texas5.3_1251
Mar 5, 2016 08:10 PM
Wolftrk99
Dec 3, 2015 08:12 PM
mitchellmade
Sep 27, 2015 08:27 PM
01silvy
Sep 26, 2015 10:20 PM
xtrooper89
Sep 21, 2015 06:03 AM
